Author Topic: vnt's?  (Read 7754 times)
Reply #15March 29, 2010, 08:45:15 pm
Re: vnt's?
« Reply #15 on: March 29, 2010, 08:45:15 pm »
Only if you have a poorly designed system that is slow to react.
I was talking about if he didn't have a controller, just a cable connecting the vane lever to the go pedal.
Reply #16March 29, 2010, 08:53:55 pm
OM617
Re: vnt's?
« Reply #16 on: March 29, 2010, 08:53:55 pm »
Thats not a good way to handle control. Lots of moving parts exposed to the elements, it can still only limit boost to one setting and it gives a funky throttle feel.
Reply #17March 29, 2010, 09:08:53 pm
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
Re: vnt's?
« Reply #17 on: March 29, 2010, 09:08:53 pm »
sooooo, I need an electronic controller?  I was under the rather destinct impression that the direct link is the best Idea especially with a modded pump where the pedal goes down the fuel goes up and at the same time boost enguages and more fuel is added via the LDA are the proportions incorrect? I do understand that that there are some finite adjustments that are going to have to be made, but that comes a bit later, this post is mostly about choosing the right VNT/s to use for what I want to achieve.  The vc has an EC unit already on it, but the IDI is inherently non-electronic, and I really don't want it to be more complicated than it already is.  The throttle is exactly the way that I want to feel it, I like to be able to feel my car and give her what she needs ::) ;D ;)  I am also here for advice, from vnt owners, and I'll take all that I can get.
thanks guys, and keep it comin,
Kevin
Reply #18March 29, 2010, 09:12:27 pm
NintendoKD
  • 931
    • myspace page
Re: vnt's?
« Reply #18 on: March 29, 2010, 09:12:27 pm »
oh, and for the uninformed, I'm here for the BEST way, "whatever that means"  for performance and longevity, as well as dummy proof "I need that last one, I am a MARINE, remember folks :-["  if the best way is to use an electronic controller, then I guess I have some learning to do in that regard, and if the best is my way then I know I'm on the right track, but if there is another way that is better, I will change my plans to just that.  Not! wishy washy. ::)
Reply #19March 29, 2010, 09:17:47 pm
Re: vnt's?
« Reply #19 on: March 29, 2010, 09:17:47 pm »
If you search a bit here you should find numerous threads discussing/debating all the various ways to mechanically control a VNT.   ;)
In particular, Andrew has published a couple of detailed mechanical controller construction threads.
Reply #20March 29, 2010, 09:20:38 pm
NintendoKD
  • 931
    • myspace page
Re: vnt's?
« Reply #20 on: March 29, 2010, 09:20:38 pm »
I have seen it, just having a tough time locating it, now that I know the author, it should be a cinch.  This is the way to go right Vince?  This thread has gotten me a bit befuddled ???
thanks,
Kevin
Reply #21March 29, 2010, 09:36:43 pm
NintendoKD
  • 931
    • myspace page
Re: vnt's?
« Reply #21 on: March 29, 2010, 09:36:43 pm »
"troll alert" ok, so I got a couple of mech vnt controller threads from here: but couldn't find Andrews writeup
http://www.vwdiesel.net/forum/index.php?topic=21424.0
http://www.vwdiesel.net/forum/index.php?topic=19398.0
correction, one of them appears to be Andrews, case of mistaken Identity, sorry Andrew, and thanks.  Anything else, more upto-date than that please let me know.
Thanks,
Kevin
Reply #22March 29, 2010, 09:44:01 pm
Re: vnt's?
« Reply #22 on: March 29, 2010, 09:44:01 pm »
Those were the threads I was thinking of.  ;D
In terms of which is "better", electronic or mechanical... well... they both have their charms.
At the the end of the day it kinda boils down to skill level.. I've yet to see an off-the-shelf generic electronic control that didn't require some pretty specialized hardware and software knowledge to construct and tune... mechanical controls are much more assessable to the average dude and if adjusted properly can deliver a very nice control function.
Right, Andrew??!! ;)
« Last Edit: March 29, 2010, 09:49:34 pm by Vincent Waldon »
Reply #23March 29, 2010, 10:01:13 pm
NintendoKD
  • 931
    • myspace page
Re: vnt's?
« Reply #23 on: March 29, 2010, 10:01:13 pm »
I don't honestly think that I truly understand Andrews design though, and will need some help collecting the parts and assembling it.  I understand the concept though "just look at my signature, LOL ;D"  I still need advice on the best vnt combo to go with :'(
thanks,
Kevin
P.S. Yes, I thought that the "Toll Alert" was a nice touch, no harm done though 8)
Reply #24March 30, 2010, 02:28:11 am
Re: vnt's?
« Reply #24 on: March 30, 2010, 02:28:11 am »
I'd say electronic undoubtedly provides;
the fastest response time
the most tuning options
self diagnostic capability
and more, but without a Holset or Garrett engineering team, Bosch, and the OEM's backing your play, you may just have to suffer with the rest of us.
So far i've seen one system which can override the CANBUS controller, but I don't think it works standalone.  I have a perfect working controller, I just can't tell it what to do :(
http://www.holset.co.uk/mainsite/files/3_1-magazines.php   check out edition 10
Reply #25March 30, 2010, 06:09:10 am
NintendoKD
  • 931
    • myspace page
Re: vnt's?
« Reply #25 on: March 30, 2010, 06:09:10 am »
good find, and a very good read, I especially liked the axially horizontal turbo idea, interesting way of thinking.
Reply #26April 03, 2010, 05:23:52 am
NintendoKD
  • 931
    • myspace page
Re: vnt's?
« Reply #26 on: April 03, 2010, 05:23:52 am »
what about one from a 98 afn code passat from the uk? which vnt is that?  I would like to know so I can buy it if it is what I am looking for.
Reply #27April 19, 2010, 09:56:17 pm
NintendoKD
  • 931
    • myspace page
Re: vnt's?
« Reply #27 on: April 19, 2010, 09:56:17 pm »
GRRRRRR! >:(  Having a helluvah time finding a pd150 turbo, 1749vb right? I need the part no.s or something that I don't have because I can't find them by searching for pd 150, pd, gt1749vb, or anything else, maybe I found some, but the thing is I don't have the part no. so I cannot confirm.  I want to make sure I get the right one.  Perhaps I should go back to the drawing board on this one and search another way?  I don't want boost too early, even though I will have forged H-beam chromoly rods, but I don't want it too late, with modification, I can recombine these things many ways but I though I had something going here.  Any one help me here, I guess the search system is a bit different, because I have never had this hard of a time finding auto parts in the us ebay.  Can anyone give me a hand? I could buy a 1722 hybrid, but where is the fun in that?  and besides, after I buy the two turbos individually from someone in the UK "breakers/etc." I will save that much more money on my build, as my friend will assist me with the fabrication, and turbo rebuild.
thanks,
Kevin
Reply #28April 19, 2010, 10:18:31 pm
NintendoKD
  • 931
    • myspace page
Re: vnt's?
« Reply #28 on: April 19, 2010, 10:18:31 pm »
K, so I just tried to use 1.9 tdi as a search string, but I got so many results now I can't find or figure out which I need :'(  any help would be awesome guys
Thanks,
Kevin
Reply #29April 20, 2010, 11:26:31 am
NintendoKD
  • 931
    • myspace page
Re: vnt's?
« Reply #29 on: April 20, 2010, 11:26:31 am »
I want to use the mech control that you have come up with, I like it.  I have been having issues wrapping my mind around it but now it is all ok.  I would like to know where you got the parts from as well as which boost can to use, my application will be a bit different becaus eof the amount of boost I will be using, as well as the turbo being used.
thanks,
Kevin
