Author Topic: Performance Build Help??  (Read 2460 times)
March 12, 2010, 05:52:24 am
ein bora
  • 377
« on: March 12, 2010, 05:52:24 am »
So okay I'm planning on building a performance diesel for my daily driver. What I have available to me is a 1.6 n/a and a 1.9 td. Some of the parts I have already collected and am planning to use is a PD150 intake, intercooler, giles pump, GTB2056V turbo, 3" exhaust. I also have a 5 cyl td out of a audi 5000 that I was saving for another project, but it does have a 10mm pump that I could have re-done/giles of coarse, if it were a benefit.
So question - what would be a good mix and why, and what should I still be looking at getting.
Any thoughts/idea's appreciated. Thanks.
« Last Edit: March 12, 2010, 05:59:59 am by ein bora »
If you can't take advice - then you can't be helped!
Reply #1March 12, 2010, 06:33:39 am
Re: Performance Build Help??
« Reply #1 on: March 12, 2010, 06:33:39 am »
Depends...
is your daily a kenworth or a vw rabbit?
I say 1.6 all the way as it is awesome, but to each his own.
Reply #2March 12, 2010, 06:36:15 am
ein bora
  • 377
« Reply #2 on: March 12, 2010, 06:36:15 am »
Depends...
94 - 1.9 IDI jetta - but it will be a Peterbuilt.
Reply #3March 12, 2010, 08:24:17 am
rabbid79
  • 684
« Reply #3 on: March 12, 2010, 08:24:17 am »
Unfortunately the 5-cyl isn't going to physically fit or mount up to the transmission in your Jetta.
'15 WRX
Reply #4March 12, 2010, 08:46:13 am
« Reply #4 on: March 12, 2010, 08:46:13 am »
Ontario is very plentiful for TDI's.. what about sellin off what you got and going that route? getting the whole car to donor everything you would need the swap should should be a cinch.
Reply #5March 13, 2010, 05:42:26 am
macka
  • 957
« Reply #5 on: March 13, 2010, 05:42:26 am »
I think you should seriously consider Jeremy's suggestion. You'll get your petercar and the VNT. ALl you'd really need to add is an intercooler and EGT gauge.
Quote from: Vincent Walden
