Author Topic: I dont understand why?  (Read 5748 times)
March 08, 2010, 02:46:48 pm
xxkoadyxx
  • 179
« on: March 08, 2010, 02:46:48 pm »
Im having probs with my car starting when not plugged in over night, even in this mild 5-10c temps, i checked to see if the plugs are getting voltage and they are, i have a new water pump and alternator lol prob less than 500kms, but car even takes a bet to start even while pluged in, im thinking maybe the starter but not sure, do u have any ideas?
93 vw Golf 1.9TD soon to be stage 3 malone TDi (project)
2003 VW 1.8T Passat (daily)
Reply #1March 08, 2010, 03:30:08 pm
rallydiesel
  • 1880
Re: I dont understand why?
« Reply #1 on: March 08, 2010, 03:30:08 pm »
Just because the plugs are getting power doesn't mean they are good. Does the starter sound fast or does it struggle after a couple seconds? Do you have any smoke out the exhaust? There's several possibilities for hard starting when sitting a while. Does it start fine when it's warmed up?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2March 08, 2010, 03:41:26 pm
« Reply #2 on: March 08, 2010, 03:41:26 pm »
Reply #3March 08, 2010, 04:03:07 pm
Henchman
  • 183
« Reply #3 on: March 08, 2010, 04:03:07 pm »
Without knowing anything else, I vote glow-plugs.  Finally changed mine last fall, was so bad that it would take forever to start anytime the temp got down into single digits.  All 4 were bad.  After change, starts after 1/2 rotation (on warmer days).
Ian
Reply #4March 08, 2010, 05:51:17 pm
« Reply #4 on: March 08, 2010, 05:51:17 pm »
A voltage drop test may also be in order
http://www.vwdiesel.net/forum/index.php?topic=22321.0
Reply #5March 09, 2010, 03:33:28 am
xxkoadyxx
  • 179
« Reply #5 on: March 09, 2010, 03:33:28 am »
The car starts up right away when the car is up to temp.
Reply #6March 09, 2010, 03:43:32 am
catlin_cava
  • 1954
« Reply #6 on: March 09, 2010, 03:43:32 am »
shouldn't you be at school  ;D
Ok something of use lol. My 97 AAZ was doing the same thing yours is doing. New Battery, New GP's, New starter, Replced the altenator and it was still hard starting at first. and Idled really rought at first.
When you pull the cold start out, does the idle settle down right away or does it still run rough?
Mine the pump was starting to go.
« Last Edit: March 09, 2010, 03:57:11 am by catlin_cava »
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #7March 09, 2010, 04:07:19 am
xxkoadyxx
  • 179
« Reply #7 on: March 09, 2010, 04:07:19 am »
When i pull the cold start out,it does settle down right away the ca sounds as if it changes tone, i started it just a min ago and it took a bit to get going without the CS pulled, but it did settle down after.
Reply #8March 09, 2010, 07:01:56 am
« Reply #8 on: March 09, 2010, 07:01:56 am »
i vote glow plugs too. did you actually visually check to see that the tips are getting red hot? just because there is power to the end does not mean the tip is getting hot.
Reply #9March 09, 2010, 07:15:01 am
ein bora
  • 377
« Reply #9 on: March 09, 2010, 07:15:01 am »
Maybe fuel supply issues? - when's the last time the filter has been changed?? Could the timing be out - have you or anyone done any work on the pump lately??
Check the glows first of coarse, take them out and if they are working I'd start with the fuel filter as it could be plugged.
If you can't take advice - then you can't be helped!
Reply #10March 09, 2010, 09:03:32 am
« Reply #10 on: March 09, 2010, 09:03:32 am »
Which tells you your fuel system, timing, etc are probably close enough.
All things being equal, cold starting is about compression and... you guessed it... your glow plugs.   ;)
Reply #11March 09, 2010, 12:01:50 pm
xxkoadyxx
  • 179
« Reply #11 on: March 09, 2010, 12:01:50 pm »
alright ill check the glow plugs, but how do ii get at the one behind the IP? just sqweez my hand inn there?
Reply #12March 09, 2010, 04:20:31 pm
Patrick
  • 1034
« Reply #12 on: March 09, 2010, 04:20:31 pm »
Use a wrench to loosen the nut, but leave it attached to the buss bar. Then use a wrench to remove the plug from the head. Buss bar makes a handy tool to swing everything out and back in..............
Reply #13March 09, 2010, 05:36:53 pm
« Reply #13 on: March 09, 2010, 05:36:53 pm »
Remove the injection lines. Keep them as a set if they still have the clamps on them.
Reply #14March 11, 2010, 01:28:54 pm
macka
  • 957
« Reply #14 on: March 11, 2010, 01:28:54 pm »
If you move the fuel lines, its 10 times easier then dicking around, and about 40 times faster.
Quote from: Vincent Walden
