Author Topic: German Dash cluster  (Read 2284 times)
March 06, 2010, 03:48:39 pm
dokarex
  • 61
German Dash cluster
« on: March 06, 2010, 03:48:39 pm »
Got my diesel dash cluster from Germany with tach (160CDN on ebay.de)  couldn't wait to get home and install it, went to Tim Hortons and while in the drivethrough I thought well I'll start taking the dash apart, well by the time I got my coffee the new dash was installed (didn't get the cover back on) but it was plugged in and working  The cluster is a little rough with some PO soldering but it works and now I have a tach, tripmeter, clock(works :o),and a 100000's odo instead of 10000's
If I wasn't to big too do cartwheels that's what I would be doing.(I was going crazy trying to figure out what to use for a tach).
1987 1.9TD Doka from Germany gasser DU tranny, fuel turned up, 1.6 LDA pin, boost at 15 psi,egt and boost gauges,stock diesel tach,air filter behind passenger tail light, IC to come
2005 Jetta Wagen TDI
B6200 Kubota Diesel
16ft Freestyle catermeran
16ft Sunray 85HP
Reply #1March 10, 2010, 04:42:33 pm
zagarus
  • 619
Re: German Dash cluster
« Reply #1 on: March 10, 2010, 04:42:33 pm »
OEM will always make you happy you didn't get a massive autometer tach with super sweet LED shift light lol.
Reply #2March 10, 2010, 09:29:08 pm
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
« Reply #2 on: March 10, 2010, 09:29:08 pm »
this is for a "     " insert mk style no. here. ???
Reply #3March 12, 2010, 10:36:13 am
dokarex
  • 61
« Reply #3 on: March 12, 2010, 10:36:13 am »
It's for the Vanagon Doka so no MK code but it looks great and works great.
B6200 Kubota Diesel
16ft Sunray 85HP
