Author Topic: vacuum pump  (Read 6867 times)
March 01, 2010, 09:26:48 pm
dyoungen
  • 128
vacuum pump
« on: March 01, 2010, 09:26:48 pm »
How do I tell what type of vacuum pump I have? My Jetta is a 1985 Jetta Delux n/a with a 5 speed and very little brakes.
Reply #1March 01, 2010, 09:32:06 pm
Turbinepowered
  • 1206
Re: vacuum pump
« Reply #1 on: March 01, 2010, 09:32:06 pm »
If it looks like you have a small soup can sitting where a gas car would have a distributor, you have a rotary vane vacuum pump.
If you have a funky looking contraption like a UFO turned on its side and hanging off a shaft, with a box on the other side, you have a diaphragm pump.
Reply #2March 01, 2010, 10:39:30 pm
Re: vacuum pump
« Reply #2 on: March 01, 2010, 10:39:30 pm »
BEST DESCRIPTION EVAAAAAAARRR!!!!!!!!!!  ;D ;D ;D ;D ;D
Reply #3March 02, 2010, 08:27:34 am
Turbinepowered
  • 1206
Re: vacuum pump
« Reply #3 on: March 02, 2010, 08:27:34 am »
*Takes a bow* Thank you, thank you, I'll be here all week!
Reply #4March 03, 2010, 10:01:37 am
dyoungen
  • 128
Re: vacuum pump
« Reply #4 on: March 03, 2010, 10:01:37 am »
Thanks guys, looks like I have the rotary vane vacuum pump. Can these be rebuilt or do they have to be replaced?
Reply #5March 03, 2010, 10:51:44 am
jseeley
  • 106
Re: vacuum pump
« Reply #5 on: March 03, 2010, 10:51:44 am »
They can be rebuilt (I hear this a regular maintenance with the rotary pumps) I have a vane pump so I dunno too much else about them.
http://www.germanautoparts.com/Volkswagen/Golf/Engine/416/1
85 Golf Diesel 1.6 NA 240K miles? (odometer broken)
87 Cabriolet 1.8 Gasser 104K miles
05 Golf 2.0 Gasser 66k miles
03 Jetta Wagon TDI 112k Miles
Reply #6March 03, 2010, 11:05:11 am
Re: vacuum pump
« Reply #6 on: March 03, 2010, 11:05:11 am »
IFAIK vane pumps never fail and therefore aren't rebuildable :P.
Diaphragm pumps otoh fail yearly :(
Reply #7March 03, 2010, 12:03:21 pm
Turbinepowered
  • 1206
Re: vacuum pump
« Reply #7 on: March 03, 2010, 12:03:21 pm »
Check all your vacuum hose connections and bleed the brakes before you go shotgunning parts at the system.
As state, the rotary vane pumps are practically indestructable, and very rarely fail. Replacing a good pump with another good pump when it's a crack in the big fat vac hose to the booster that's the problem does nothing but lighten your wallet.
Reply #8March 05, 2010, 07:40:37 pm
ldeikis
  • 56
Re: vacuum pump
« Reply #8 on: March 05, 2010, 07:40:37 pm »
What sort of very little brakes do you have? (just to make sure we're all beating the same bush).
When the vacuum pump is kaput (or the hoses leaking horribly) the car stops fine, you just have to push like all hell on the pedal.   The pedal, in turn, feels about as giving as a brick.  Instead of going down firmly like normal, it feels like you're stepping on a...  softball maybe?  There's just the tiniest bit of give.
The vane pumps are supposed to be invincible, so look hard elsewhere before spending money.  Also, because they're invincible, they're plentiful in junkyards etc (unless someone with an earlier car swiped it--they're a straight drop in on mk1s).  PartsPlace etc sell them for an awful lot of money, but you should be able to score one used without huge difficulty.
Luke
81 Rabbit 1.6 N/A
Reply #9March 10, 2010, 07:02:37 am
Re: vacuum pump
« Reply #9 on: March 10, 2010, 07:02:37 am »
for picture reference..
Rotary/Vane on top, Diaphragm on bottom :)
Reply #10March 10, 2010, 07:25:40 am
Re: vacuum pump
« Reply #10 on: March 10, 2010, 07:25:40 am »
put a TB cover on that thing jeremy. it will thank you next time a rock comes up that way.
Reply #11March 11, 2010, 08:32:00 pm
Re: vacuum pump
« Reply #11 on: March 11, 2010, 08:32:00 pm »
Haahaa NO WAY kevo I rock the no cover styleee.. I just need to get it cleaned, prepped and painted and its back on (after then engine gets a huge degrease lol
