Author Topic: Camshafts. Need some help.  (Read 1880 times)
March 01, 2010, 01:35:54 am
Sierra94
  • 123
    Dieselsmoke in every stroke... M-Tdi Mazda!!
    • http://www.garaget.org/sierra94
« on: March 01, 2010, 01:35:54 am »
According to VAGcat a Passat from -95 with a 1Z engine uses a camshaft with part# 026109101A and so does a Golf from -85 with a JR 1.6 engine and some AAZ:s from various years.
I´ve read some other posts about camshafts and some say that AAZ is different from 1Z?
What is true?  ::)  I might aswell take the valvecover of and check what cam I use right now.
I also have a cam from an AEF engine. 1.9 NA. Is that one even better to use for a TD? Does a NA cam have longer duration?
I know my brother uses NA cams in his 1.8T Audi A4 for more hp.
Can someone chime in. I hate to be outside in this neverending winter swapping cams for no improvement at all.
« Last Edit: March 01, 2010, 02:04:23 am by Sierra94 »
<-- My M-tdi Mazda B-1800 and my other cars
Reply #1March 01, 2010, 04:52:24 am
ein bora
  • 377
Re: Camshafts. Need some help.
« Reply #1 on: March 01, 2010, 04:52:24 am »
Not related to your question but I too had wondered about the different cams. I had one from a na 1.6 so after a cam follower broke on my 1.9 IDI and damaged the cam lobe a bit - I asked here and tried it. The general consensus was it would work as there would only be slight differences - I can't say notice any difference at all.
I guess one way would be to try it, spin it by hand before starting it up of coarse, and if it spins freely - starter up and see.
If you can't take advice - then you can't be helped!
Reply #2March 02, 2010, 07:48:41 am
« Reply #2 on: March 02, 2010, 07:48:41 am »
from what i remember, the 1.6 cams have the best profile of stock vw diesel cams.
