Author Topic: the difinitive prechamber size thread  (Read 13933 times)
February 27, 2010, 07:15:58 am
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
« on: February 27, 2010, 07:15:58 am »
Ok, so I stared this thread in the hopes that it could be added to the faq, in the way that others may use the information therein.  It occurs to me that precups are becoming more and more dificult to come by, and there must be a solution, however, until that solution is discovered, we are stuck to using precups from another head, USED.  Willl this fit that, that sort of thing, will 1.6 N/A fit AAZ? will 1.5 fit 1.6 Turbo?  what are the dimensions and gains/losses of said swaps.  There is a lot to be learned gents so please pipe up.
thanks,
Kevin
Reply #1February 27, 2010, 03:02:48 pm
MRTANGOMAN
  • 51
Re: the difinitive prechamber size thread
« Reply #1 on: February 27, 2010, 03:02:48 pm »
Check this site out
http://www.eurocartogliani.191.it/EN-FrameBase.htm
looks like the N/A and TD 1.6 are the same, the 1.9 and 1.5 are both different..
Reply #2February 27, 2010, 03:37:09 pm
MRTANGOMAN
  • 51
« Reply #2 on: February 27, 2010, 03:37:09 pm »
ok some sizes in mm
                                                width @ head face      width inside head       height of the flange
1500 diesel (oem p/n 068103391)          30                            25.35                         3,75
1600 n/a td (oem p/n 069103391)         32                             27.3                          4
1900 n/a                                           30                            25.35                         4
1900td       (oem p/n 028103391m)        32                            27.8                          4
ALL MEASUREMENT TAKEN FOR THE WEB SITE LISTED IN MY POST ABOVE!!
THESE ARE FOR REFERANCE ONLY , ANY MISTAKES, NOT DOWN TO ME
Reply #3February 27, 2010, 04:28:12 pm
NintendoKD
  • 931
    • myspace page
« Reply #3 on: February 27, 2010, 04:28:12 pm »
thanks tango, this should be very useful to many here on the forum.  any way you could get pictures for comparison?  or pictures period, there may be other differences that are pertinent.
Reply #4February 27, 2010, 05:21:21 pm
maxfax
  • 2126
« Reply #4 on: February 27, 2010, 05:21:21 pm »
IIRC, someone once mentioned that there is a difference in the cups between the hydro and mech heads. I don't recall what this difference was supposed to be, but I recall this coming up at one point...
Reply #5February 27, 2010, 06:47:25 pm
« Reply #5 on: February 27, 2010, 06:47:25 pm »
I "quick" search showed this: http://www.vwdiesel.net/forum/index.php?topic=20075.0
http://www.vwdiesel.net/forum/index.php?topic=20672.0
There's a lot more but lots of the info is contained in some loooooooong threads ;D
Reply #6February 27, 2010, 08:02:08 pm
NintendoKD
  • 931
    • myspace page
« Reply #6 on: February 27, 2010, 08:02:08 pm »
hence the nice, short, thread with up-to date information. ;D
Reply #7May 24, 2010, 10:16:15 pm
NintendoKD
  • 931
    • myspace page
« Reply #7 on: May 24, 2010, 10:16:15 pm »
I agree, does someone have access to the 1.5 1.6N/A 1.6 TD and 1.9 cyl heads as well as the L5 audi/VW head then we can get some real answers.
Reply #8May 25, 2010, 08:29:42 am
« Reply #8 on: May 25, 2010, 08:29:42 am »
i have 1.5 cups, 1.6 n/a cups 1.6 TD cups, and audi 2.0 5 cyl cups.. what measurements do we need?
Reply #9May 25, 2010, 08:40:38 am
NintendoKD
  • 931
    • myspace page
« Reply #9 on: May 25, 2010, 08:40:38 am »
actual cc containment, diameter both at the bottom and at the lip, in other words, to find out if the prechambers can be exchanged from one head to the next.
thanks ROR,
Kevin
Reply #10May 25, 2010, 09:22:14 am
« Reply #10 on: May 25, 2010, 09:22:14 am »
i have no way to CC these things, unless its with water and a graduated syringe.. and thats just going to be a close measurement. i have a set of standard calipers. nothing beyond that really.
Reply #11May 25, 2010, 02:08:38 pm
« Reply #11 on: May 25, 2010, 02:08:38 pm »
I know on the GM diesels, the port varies in shape and size by application as well.
Reply #12May 25, 2010, 05:35:12 pm
NintendoKD
  • 931
    • myspace page
« Reply #12 on: May 25, 2010, 05:35:12 pm »
maybe there is a tech page somewhere that lists the cc containment no's but the depth and diameters, as well as other dimentionL details will be very helpful in this thread maybe one of our senior members can assist with this.  Maybe a Machinist? Jedi Master Giles?
Reply #13May 25, 2010, 07:23:52 pm
« Reply #13 on: May 25, 2010, 07:23:52 pm »
on GM's the n/a J-code heads have the biggest ports and flow the best in factory form.
Reply #14May 28, 2010, 12:08:10 am
NintendoKD
  • 931
    • myspace page
« Reply #14 on: May 28, 2010, 12:08:10 am »
Thats interesting. I've computed the following from engine data tables:
1.5 Swirl chamber volume 11.457 cc
1.6 Swirl chamber volume 12.794 cc
1.9 Swirl chamber volume 16.376 cc
found this in another thread, thanks krautster 8)
