Author Topic: 83 Volvo 240 Wagon D24 Engine Swap to D24T  (Read 30933 times)
February 26, 2010, 04:00:40 pm
dennis
  • 311
« on: February 26, 2010, 04:00:40 pm »
I Know this is the Non VW section but this is sort of VW. Im swapping a D24T engine from an 84 760 D24T into my 245 Wagon. This should be easy but today I found out that the turbo engine will not turn over a complete revolution. So far I got the engine out. Cam is out of the engine still no turn. Probably a nice rust ring in one or more cylinders. The head, and oil pan come off tomarrow. This will probably mean boring, and pistons. Crap. I had really hoped to just freshen it up a bit with rings, and bearings. Pics to follow. Oh did I mention the turbo is locked up too.
1980 Caddy TD (Always in progress)
1983 Volvo 245 D24 NA Building D24T
1980 Air-cooled Westy
1956 F100 (What to do???))
Reply #1February 26, 2010, 04:09:59 pm
Re: 83 Volvo 240 Wagon D24 Engine Swap to D24T
« Reply #1 on: February 26, 2010, 04:09:59 pm »
somebody blow a head gasket and park it?  I dont think I've seen one locked up yet.
Reply #2February 26, 2010, 07:45:16 pm
dennis
  • 311
« Reply #2 on: February 26, 2010, 07:45:16 pm »
Parked 5 + years. Both timing belts well used. When I took the cam out all the valves appeared seated. I have always had better service out of a standard bore. I really hate to have it bored out. Im hoping oversized 1.6 T pistons are the same. You need anything from this car? Not the same trans as the gasser Volvos either. The Garret turbo looks pretty much like the gasser turbos. I have a 745 gasser turbo. The diesel one ils locked up.
Reply #3February 27, 2010, 01:52:24 pm
dennis
  • 311
« Reply #3 on: February 27, 2010, 01:52:24 pm »
Turns over great with the head off. A lot of rodent debris in a couple of cylinders. Im gonna have to get my shots updated after messing with this car.
Reply #4February 27, 2010, 04:22:30 pm
« Reply #4 on: February 27, 2010, 04:22:30 pm »
No, the squirter notch is 90* off.
ZF 4HP22E?  some gassers use it, as well as MBX, land rover, and about 20 other cars.
Fill the oil part of the turbo with  some mystery oil or something for a day, it might just be varnish stiction.
Its a T3 bolt pattern, but I think our exhaust side is smaller than most of the gassers.
Reply #5February 27, 2010, 09:08:59 pm
dennis
  • 311
« Reply #5 on: February 27, 2010, 09:08:59 pm »
[ZF 4HP22E?  some gassers use it, as well as MBX, land rover, and about 20 other cars.
[/quote]
 The trans to you $50.00 + shipping. the car originally layed down over engine problems. I will get you the exact numbers off it Monday. I would imagine that the bell housing is somewhat rare these days. The only other thing according to the PO. All I want from the car is the diesel tach. The diff is non LSD so no gain for me there. Did Vovo sell one? One would think so because of the weather in Sweeden. I am in need of a manual trans. Mine chatters though I may replace main shaft bearings. the OD unit looks to have been replaced recently. I'll seperate the turbo sections and soak em in some tranny fluid, but I need to pick some brains to see what else might be an improvement. Got the engiendown to the bare block today. All the pistons look good. Rings were the only thing worn out. Doe have a bit of a ring ridge. Going to get it washed and measured to see If I need to bore it or not Monday. My 245 body is rock solid. I love old ugly junk.
Reply #6February 27, 2010, 09:40:30 pm
« Reply #6 on: February 27, 2010, 09:40:30 pm »
the bellhousing is somewhat rare, but I wouldn't put an auto in my car if you paid me $50 :D
---though the though of mating one to a land rover tranny has crossed my mind.
240s have a very rare true-trac option, and very late models may have the Eaton G80 locker.  the locker from a late 740/940 can fit a late 240 diff if you shorten one axle a hair.
The diesel manual trans is a standard M46, but the OD may have a different ratio  (a few gas cars have the M47 5 speed instead).
as for Turbo... A Holset bolts to the manifold....
Volvo 740 2.4 Turbodiesel test
Reply #7February 28, 2010, 09:11:46 am
dennis
  • 311
« Reply #7 on: February 28, 2010, 09:11:46 am »
Your the king. That vidieo is bad ass. I just checked car-part.com and it looks like the manual trannys are the same for 740 and 240 88 and up. I am hoping that the difference in the older ones and newer ones is the bell housing having a hole for the gasser crankshaft position sensor. My Wagonn is an 83.  Im thinking the 4 speed OD may not hold up. I have a gasser 745 turbo parts car w/automatic. How do I ID that diff.
« Last Edit: February 28, 2010, 09:36:04 am by dennis »
Reply #8February 28, 2010, 10:06:43 am
MJF
  • 581
« Reply #8 on: February 28, 2010, 10:06:43 am »
I know the Volvo owner. That Volvo has dynoed 297hp (I´ve seen the dynosheet). Stock internals, Holset HX40 Super and 12mm pump.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #9February 28, 2010, 02:26:57 pm
« Reply #9 on: February 28, 2010, 02:26:57 pm »
:oI knew it sounded pretty pissed, but that is an impressive HP rating.
Dennis, the diesel bellhousing  is different bolt pattern from the redblock one. I'm pretty sure the diesel ones are different for a 240, as the engine mounts straight up, while  a 740 is on a slant.  At some point, the speedo was moved from the OD to the rearend, and ABS cars have a different speed sensor that needs 2/3 of its teeth removed to work with earlier speedos.
I wouldn't worry  too much about the 4 speed till you make at least as much power as a gas turbo car.
this help your ID? http://www.brickboard.com/FAQ/700-900/Driveline.htm#RearAxleRatioTable
Reply #10February 28, 2010, 06:51:35 pm
dennis
  • 311
« Reply #10 on: February 28, 2010, 06:51:35 pm »
Yeah. I understand the bell housing difference. VW to Volvo = special. I am just looking to go to a standard 5 speed. Will the later 5 speed trannys bolt up to the diesel bell housing that is currently bolted to my 4 speed with the electric 5th gear? Longer or shorter driveshafts I can have done down the street. The speedo cable as you mentioned is a concern though. Even the 84 760 Im killing has a speed sensor on the diff for the speedo. Gonna have to study that circuit if Alldata has the info to see if I can adapt it to the 83 245. Im keeping the 760 instrument cluster anyway. It has a diesel tach. After some thought I really don't know of any huge problems with the 4 speed OD units. The one in my car has 250K + miles, but chatters. Might be able to freshen it up with mainshaft bearings. I don't recall in ten years of working on these cars of ever replacing one. Just occassional clutch jobs. Both 760 TD and 240 NA are mounted on a slant, and appear to use regular gasser 240 motor mounts. I can compare part numbers tomarrow.
Reply #11February 28, 2010, 08:24:16 pm
« Reply #11 on: February 28, 2010, 08:24:16 pm »
The M47 5speed  is an M46 with 5th in a chunk bolted to the back instead of in the Laycock  box.  3rd gear, and the mainshaft bearing are the same, and where either generally blow apart on 3-4 upshift or pulling hard  at the strip.  The M90 I think has a different bellhousing, and has to be imported from Europe, and is stronger, but maybe not as good as a T5.
Volvo mounts were harder rubber for diesel, but this  apparently isn't always the case with aftermarket.
Reply #12March 01, 2010, 05:52:35 am
OM617
« Reply #12 on: March 01, 2010, 05:52:35 am »
What is the fascination with the HX40 on small engines? That turbo is way too large for only 297hp and its actually making performance suffer! An HX35 or HY35 would be much more suitable for it and spool up much quicker so you don't have that nasty smoke trail while waiting for the turbo to respond.
Reply #13March 01, 2010, 08:49:55 am
vwjunkie53
  • 98
    • The Volvo diesel forum
« Reply #13 on: March 01, 2010, 08:49:55 am »
Just dropping in to plug d24t.com  You should come over and join up, lots of good volvo diesel info and great knowledge base too.
The M46 trannies from the early 80s up to the m47 will swap in all you need to change is the bellhousing.  As turbogriesel said, the m47 isn't any stronger.  The early M46 trannies had a steel case which is supposed to be a little stronger, but cam with the weaker Laycock J type overdrive.  Kinda a catch 22.  The later trannies used a stronger OD but were an aluminum case.  Apparently you cant swap the overdrive units as the output shaft is a different length.  I'm sure you could take apart the trans and swap out shafts but what a PITA.  If you look over on the d24t forum there is a thread on manual transmissions, the M90 is pictured in one post next to a m46.  HUGE trans, and much much stronger.  I would say its up there with a T-5 the thing looks like it came out of a dump truck.  As for getting one in the states.... Good luck with that.  It would have to be a diesel trans as the bellhousing is cast as part of the whole trans. You couldn't find just any m90 and just a diesel bellhousing like you can with the m46...
Hope that was helpfull.
Jason
1984 Volvo 760 GLE,  "built" D24T w/ARP studs, MLS head gasket, ported/polished head, 3 angle valve job, NA cam, 56mm T3/T4, NA manifold, FMIC w/ 3" alum piping, 3" turbo back, detailed in CAT yellow. T-5 manual swapped w/ Clutchnet 6-puck.  Best of 16.07@86mph with orig. worn out engine.
Reply #14March 01, 2010, 01:30:57 pm
dennis
  • 311
« Reply #14 on: March 01, 2010, 01:30:57 pm »
Just found it while looking for oversize pistons. My block is toast with out them. Even Volvo is back ordered.
