Author Topic: vac pump base seal?  (Read 5306 times)
February 17, 2010, 01:54:26 pm
truckinwagen
  • 1895
vac pump base seal?
« on: February 17, 2010, 01:54:26 pm »
is there a gasket or an oring that is supposed to be on the base of the vac pump?
I never noticed if there was, and I think I am leaking oil from where the vac pump goes into the block.
anyone know?
-Owen
83 Opel Kadett Diesel
Reply #1February 17, 2010, 01:58:04 pm
Re: vac pump base seal?
« Reply #1 on: February 17, 2010, 01:58:04 pm »
Yes there is an o-ring. Should be the same as a distributor o-ring if you can't find one.
Reply #2February 17, 2010, 01:59:58 pm
truckinwagen
  • 1895
« Reply #2 on: February 17, 2010, 01:59:58 pm »
I will rummage around in my complete motor seal kit, might be in there with the rest of the unused/redundant bits.
thanks,
-Owen
Reply #3February 17, 2010, 06:03:39 pm
GEE-BEE
  • 1604
« Reply #3 on: February 17, 2010, 06:03:39 pm »
On aaz there is a green viton on the shaft
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #4February 17, 2010, 07:07:59 pm
jseeley
  • 106
« Reply #4 on: February 17, 2010, 07:07:59 pm »
mines got nothing there and IS leaky... I have a distributor seal on order... does it matter if you have the vane or rotary pump?
85 Golf Diesel 1.6 NA 240K miles? (odometer broken)
87 Cabriolet 1.8 Gasser 104K miles
05 Golf 2.0 Gasser 66k miles
03 Jetta Wagon TDI 112k Miles
Reply #5February 17, 2010, 07:24:10 pm
« Reply #5 on: February 17, 2010, 07:24:10 pm »
I wouldn't think so but I've never held the diaphragm style one in my hands.
Reply #6February 17, 2010, 09:37:02 pm
jseeley
  • 106
« Reply #6 on: February 17, 2010, 09:37:02 pm »
Mine is an 85, and has the newer style pump...
sadly my pump leak is the least of my issues right now...  :P
Reply #7February 17, 2010, 10:04:55 pm
« Reply #7 on: February 17, 2010, 10:04:55 pm »
So it is a confirmed drop in replacement? this is good to know, as I believe my diaphragm took a crap on me.. ;)
Reply #8February 18, 2010, 04:58:05 am
« Reply #8 on: February 18, 2010, 04:58:05 am »
I think you have to check to make sure that it is still engaging in the oil pump shaft. I think I read that there are different heights.
Reply #9February 18, 2010, 07:30:31 am
« Reply #9 on: February 18, 2010, 07:30:31 am »
Maybe I didn't put enough emphasis on "should be" when I said they are the same. I'm not 100% sure, just pretty sure.
That's good to know about the one in the bottom.
Reply #10February 18, 2010, 07:45:10 am
« Reply #10 on: February 18, 2010, 07:45:10 am »
im pretty sure i dropped a gasser dizzy in a diesel block before. 99% for sure they are the same. the 2.0s have a bigger hole in the block tho.
Reply #11February 18, 2010, 08:17:57 am
« Reply #11 on: February 18, 2010, 08:17:57 am »
Yeah the 2.0 should match the AAZ vac pump
Reply #12February 18, 2010, 08:59:00 pm
  • 2926
« Reply #12 on: February 18, 2010, 08:59:00 pm »
Here's the seal Andrew is talking about:
 It's usually a hard old black piece that looks like part of the pump. Keeps oil pressure frrom bleeding off.
 Not sure where the best place to buy them is, I get them from the dealership.
 Don't know the part number right off either.
NAPA has an o-ring that fits, can't remember the size, took a vacuum pump in to test fit.
Reply #13February 19, 2010, 09:45:58 am
  • 2926
« Reply #13 on: February 19, 2010, 09:45:58 am »
Are you sure?
 That doesn't add up.
 10mm difference between inside diameter and outside,
 but only 3mm thickness?
Reply #14February 19, 2010, 09:53:35 am
« Reply #14 on: February 19, 2010, 09:53:35 am »
The base o-ring should be 36mm ID x 46mm OD x 3mm thickness.
tsk tsk tsk......... :D
