Author Topic: How do you unblock wastegate??  (Read 2488 times)
February 14, 2010, 02:11:36 pm
91jettaidi
« on: February 14, 2010, 02:11:36 pm »
Hi guys I had a 91' Jetta TD then I sold it. Now i'm buying the same car back from the guy but he said that he blocked waste-gate and some thing else. I just wanted to know how can i do it. I have know idea where to start if some one can help me out that would be great. Also how long can I drive with a broken rack and pinion.  THANKS
Reply #1February 14, 2010, 03:18:24 pm
91jettaidi
Re: How do you unblock wastegate??
« Reply #1 on: February 14, 2010, 03:18:24 pm »
PFFFFT who needs steering, lawl, ok i didn't know it would get that bad thanks for that. I have the part just i tend to spend money on every thing else but that.
Reply #2February 14, 2010, 03:23:44 pm
« Reply #2 on: February 14, 2010, 03:23:44 pm »
There's several ways to block off the wastegate... can he tell you what he did?
Reply #3February 14, 2010, 04:05:11 pm
91jettaidi
« Reply #3 on: February 14, 2010, 04:05:11 pm »
He said some thing about a screw
Reply #4February 14, 2010, 04:09:37 pm
91jettaidi
« Reply #4 on: February 14, 2010, 04:09:37 pm »
Cause the story is that i have a mint 1990 Jetta 1.8 Gas and i have a 91' Jetta TD and im going to do a swap put the diesel in the gas so i just want to make sure i don't blow the turbo or any thing
Reply #5February 14, 2010, 05:08:02 pm
dokarex
  • 61
« Reply #5 on: February 14, 2010, 05:08:02 pm »
Did he block the wastegate or the blow off valve? I think it's a common thing to block of the BOV(search), if you block the wastegate you should be building lot's of boost so check your boost gauge to see if you are.
1987 1.9TD Doka from Germany gasser DU tranny, fuel turned up, 1.6 LDA pin, boost at 15 psi,egt and boost gauges,stock diesel tach,air filter behind passenger tail light, IC to come
2005 Jetta Wagen TDI
B6200 Kubota Diesel
16ft Freestyle catermeran
16ft Sunray 85HP
