Author Topic: anybody know of a non turbo engine mod for fuel economy  (Read 16091 times)
October 28, 2005, 01:10:19 am
prysm
  • 41
    • http://www.fernski.com
« on: October 28, 2005, 01:10:19 am »
anybody knows of some simple engine modification for non turbo diesel to improve fuel consumption?
thanks
mazda B2200 2.2L R2 diesel
Reply #1October 28, 2005, 09:26:51 am
prysm
  • 41
« Reply #1 on: October 28, 2005, 09:26:51 am »
thanks for the reply
I am considering the low restriction intake as an initial step in improving fuel economy. I will also try to fabricate an a cold air intake piping with larger input to also act as air scoop.
thanks again
Reply #2October 28, 2005, 10:58:20 am
zyewdall
  • 393
« Reply #2 on: October 28, 2005, 10:58:20 am »
A number of people have put 4" ductwork to the front of the car from the intake on the NA 1.6 VWs.  From what they say, it peps them up a bit over the restrictive stock snorkel, and probably increases mileage a little because of freer breathing.  I'm going to do this on mine when I get it installed (maybe this weekend....?)
'89 Subaru 4x4 touring wagon
1976 Ford Sasquatch pickup
Reply #3October 29, 2005, 10:20:54 am
VWRacer
  • 649
« Reply #3 on: October 29, 2005, 10:20:54 am »
Boost your cold tire pressure to the max rating on the sidewall. That alone should give you a couple of MPG.
After doing the cold-air intake and tire pressuremods, the other 'big ticket' item is to openup the exhaust. Put on a set of gas engine headers and a 2 1/2" exhaust with a straight-through low restriction muffler. Diesels have no cam overlap, so don't really 'need' headers, but headers and a bigger pipe reduce backpressure and allow the engine to breath as efficiently as possible.
Those three items alone will give you nearly all the big fuel economy advances you can get. From there it's fine tuning. Advance IP timing to maybe 1.1mm (help me out here, guys!), back off the max fuel screw, etc.
Good luck and keep us advised on how it's going!
Stan
C-Sports Racer
Reply #4November 07, 2005, 10:24:53 am
houseofdiesel
  • 210
« Reply #4 on: November 07, 2005, 10:24:53 am »
I ran a cherry bomb muffler (basically no restriction resonator) on stock diameter pipes and set timing to 1.15mm lift. I increased my fuel economy about 25% (best was 900 miles a tank, worst 600 miles in -25C constant after mods) and raised the top speed to 100mph from 80. Stock intake. This car had compression 360-500-500-360 and ran well once the exhaust was openend up, I think the muffler has plugging up from soot due to poor compression and factory spec timing.
I think a cold air intake via hood scoop would work well, but I was happy enough with the exhaust mods to stop tinkering. I find shifting early helps alot too, if you play enough with the fueling and timing the engines power band seems to be 2000-2500 rpms.
Greg
Reply #5December 12, 2005, 06:50:52 pm
prysm
  • 41
« Reply #5 on: December 12, 2005, 06:50:52 pm »
just an update...
The cold air intake was a sucess. You can initially feel the effects during accelaration. fuel economy is a bit better, However I am still trying to figure out the best position for the pipes.
The header, 2.5inch exhaust and a the muffler after asking around needs to be customized and would cost too much right now so I can not impliment it :(
thanks everyone
prysm
Reply #6March 06, 2010, 02:52:36 pm
CoastalDefender
  • 47
Re: anybody know of a non turbo engine mod for fuel economy
« Reply #6 on: March 06, 2010, 02:52:36 pm »
thanks everyone
prysm
Header not changed, but I just replaced my piping and muffler 2.5" from header->out, and the bill was $32USD for the muffler, $95USD installed with new piping.
Increasing my Carbon Footprint, 10,000 gallons of BOOM at a time.
Reply #7March 07, 2010, 11:46:46 pm
« Reply #7 on: March 07, 2010, 11:46:46 pm »
Make sure your pump and injectors are like new, add an EGT gauge, and  keep it under 600*.
Reply #8June 05, 2010, 12:27:31 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #8 on: June 05, 2010, 12:27:31 pm »
Look up transfer pressure, or internal pump pressure.
my best guesses for the 1.6 TD's are as follows...
36-46psi@1000rpm, 67-75psi@3000rpm, 94-103psi@4500rpm,
these are engine rpm's. Google "hagar" and "smileage" for how to check the pressures.
Reply #9June 10, 2010, 09:16:19 am
« Reply #9 on: June 10, 2010, 09:16:19 am »
gotta love 5 year thread bumps ;) lmao
Reply #10June 10, 2010, 03:48:44 pm
« Reply #10 on: June 10, 2010, 03:48:44 pm »
Nothing wrong with that. It makes the search all that much more useful.
Reply #11June 12, 2010, 11:48:45 am
smutts
  • 720
« Reply #11 on: June 12, 2010, 11:48:45 am »
gotta love 5 year thread bumps Wink lmao
Bloody Hell, I fell for it. ::)
Reply #12June 13, 2010, 09:27:15 am
catlin_cava
  • 1954
« Reply #12 on: June 13, 2010, 09:27:15 am »
December 12th, 2005 I was rocking a 2002 VW Jetta TDI Drivers Edition in the backwoods of Nova Scotia  ;D What where you doing?
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #13June 13, 2010, 09:30:38 am
« Reply #13 on: June 13, 2010, 09:30:38 am »
drivin around a white butt rockin 80's toyota pickup.. 2wd, and lots of mpg. not like a diesel tho.. holy crap, i was 16 too...
Reply #14June 13, 2010, 12:24:54 pm
catlin_cava
  • 1954
« Reply #14 on: June 13, 2010, 12:24:54 pm »
i was in my last year of high school, and was 19 lol
Catlin
