S-PAutomotive.com
Author Topic: There must be a better way to attach wires to glowplugs!!  (Read 18104 times)
Reply #45February 17, 2010, 11:39:32 pm
Re: There must be a better way to attach wires to glowplugs!!
« Reply #45 on: February 17, 2010, 11:39:32 pm »
they may have allowed a compression leak, i dunno the specifics. I'm only 19 and Canadian.. I'm allowed to be wrong eh.  ;)
Reply #46February 18, 2010, 01:08:06 am
maxfax
  • 2126
« Reply #46 on: February 18, 2010, 01:08:06 am »
Is all in all possible they did something to change the chamber volume too..  All sorts of screwy stuff out there..
I guess you're probably too young to answer this question for me..  Back in the 30's here in the US we had the Ford Model "A"..   Was it called the Ford Model "EH" in Canada???   ;D
Reply #47December 14, 2012, 09:28:58 pm
« Reply #47 on: December 14, 2012, 09:28:58 pm »
Pimped my GPs, but neglected to ensure the trimmed ring terminal would not spread when tightening the nut.
Now (a year later), I am adding the small flat-washer on the GP studs to keep the hook/ring from spreading and allowing a more secure connection.
Reply #48December 16, 2012, 08:26:14 pm
ToddA1
  • 434
« Reply #48 on: December 16, 2012, 08:26:14 pm »
I think if you cut the notch at the top, the opening wouldn't spread.  The rotation of the nut would help keep it closed.  The only difference would be hooking the stud from the bottom.
-Todd
Reply #49December 18, 2012, 04:51:43 pm
homerj1
  • 427
« Reply #49 on: December 18, 2012, 04:51:43 pm »
I think that is called a pup motor (sp). It sounds horribly overly complicated but very clever
Two different things.
A pup motor setup is basicly a small gas engine used as a starter motor for the bigger one. I've only seen them on CAT diesels. Later ones use the small engine to heat the diesel as well as to crank it over.
Yea a older friend described how in the NY winters he'd start up a gas pup motor for a diesel dozer or grader, let  the diesel spins for a bit to warm , then hit the decompression lever to engage full compression, then maybe sometimes a hit of ether.
Reply #50April 28, 2015, 02:30:12 am
billybobf
  • 318
« Reply #50 on: April 28, 2015, 02:30:12 am »
I haven't read the pimp my glow plug thread in years.... Does it have a junction connection that allows you to separate all four glow plugs for testing individually by resistance/spark?
Reply #51April 28, 2015, 09:53:47 am
Rabbit79
  • 196
    Burns, Oregon,USA
« Reply #51 on: April 28, 2015, 09:53:47 am »
Yes. The fuse block, where you have a separate fuse for each individual glow plug. At least that's where mine diverges into 4 separate wires..... As I remember it I followed Vince's procedure pretty close all the way.
Current: 1979 Rabbit 4dr
            1984 F-250
            1999 Ford Ranger
Other v-dubs I've owned:
84 Rabbit
78 Rabbit (gasoline) flipped it end over end after driving all night and falling asleep at the wheel. RIP, it was a good little car.
70 Bug
Reply #52April 28, 2015, 04:25:21 pm
  • Administrator
« Reply #52 on: April 28, 2015, 04:25:21 pm »
I found this at Princess Auto. Absolutely perfect, even has an LED that will come on if a fuse blows.
Reply #53April 28, 2015, 07:42:49 pm
« Reply #53 on: April 28, 2015, 07:42:49 pm »
I like the fuse block with the LEDs.  The at-a-glance glow plug check would be nice.
I have a multi-meter that has a thermocouple temperature probe.  I find that if I pre-glow a cold engine a couple times, the meter is plenty sensitive enough to readily tell which glow plugs are working and which aren't.  At that point, pulling the right one is easy.
Reply #54April 28, 2015, 07:57:05 pm
  • 4391
« Reply #54 on: April 28, 2015, 07:57:05 pm »
I see a bling upgrade in my future.  Like that box and lights.  Now what to do with old blind eye when I yank it?
Reply #55May 02, 2015, 11:34:22 am
Rabbit79
  • 196
    Burns, Oregon,USA
« Reply #55 on: May 02, 2015, 11:34:22 am »
I over-engineer everything.  hehe  ::)
« Last Edit: May 02, 2015, 12:35:34 pm by Rabbit79 »
            1984 F-250
            1999 Ford Ranger
84 Rabbit
70 Bug
S-PAutomotive.com
