Fixmyvw.com
Author Topic: water pump connections  (Read 3945 times)
November 27, 2009, 12:41:47 am
2strokesmoke
« on: November 27, 2009, 12:41:47 am »
Hi guys,
I'm installing a new water pump (complete assembly-pump and housing) which
I purchased from autohausaz.
After mounting the pump, I was installing the hoses and found that one of the hoses connections was the wrong size.
My old pump had 3 connections:
1) lower rad hose
2) bypass hose to cyl head 1.032" dia
3) hose to metal pipe for heater and expansion tank  .870"  ************
NEW PUMP Graf #PA579  autohausaz #037121010a
1) lower rad hose (is the same)
2) bypass hose to cyl head 1.032" dia (is the same)
3) hose to metal pipe for heater and expansion tank  1.032"  ***********
So the new pump has a larger outlet going to the metal pipe. 1.032" instead of
.870" like my old pump.
Everything else appears to be the same.
My question is--
Can I use a different hose,to make this water pump fit my 82 VW pickup
with 1.6NA ?
I was really hoping to finish the truck this weekend- sending the pump back
to get another one-will delay this project for a week.
Ant Ideas what the new pump is for and what model VW I could order a hose for
to make this work ?
I opted to change the entire pump assembly,because mine was quite nasty=corroded,frozen bolts,ect..
I hoping the pump is for a later model,and I can just use a different hose.
I'm anxious to get this truck going agian.
Thanks in advance, Mike
Reply #1November 27, 2009, 01:19:19 am
  • 2744
Re: water pump connections
« Reply #1 on: November 27, 2009, 01:19:19 am »
The A2s have a larger hose coming from them.
 You might be able to use a MK2 hose,...
 but I can't remember if the metal coolant pipe in the MK2 is bigger also.
Tornado red, '91 Golf 4 door,
Reply #2December 02, 2009, 07:00:20 pm
boxer246
  • 109
« Reply #2 on: December 02, 2009, 07:00:20 pm »
Ok I'm pretty sure i ran into this problem a few years back.  The hose you need is the one on this page the last one pictured.
http://www.germanautoparts.com/Volkswagen/Jetta/Cooling/118/1
If you have an oil cooler then its different entirely.
Let me know if I got it right.
http://www.germanautoparts.com/images/7607a6e2d4336303132313836303/f
Ash
'81 VW Caddy 1.6 now a TD
'88 Vanagon (building a AHU M-TDI)
S-PAutomotive.com
