Author Topic: Post your vid of your 1.6/1.9  (Read 4739 times)
November 15, 2009, 10:51:39 pm
  • 3468
    • McScrubbins Body Wash
« on: November 15, 2009, 10:51:39 pm »
I was wondering if i could see some running videos of people with their 1.6/1.9
And how advanced they have their pump set?
I just changed the rings and im thinking of timing it an entire tooth advanced to start with and then push the pump towards the head once it's started till it runs right.
Reply #1November 16, 2009, 07:44:56 am
Re: Post your vid of your 1.6/1.9
« Reply #1 on: November 16, 2009, 07:44:56 am »
a whole tooth of advance is ALOT. a tooth forward with the pump as retarded as it can get, it will still be alot more advanced than your pump on the right tooth and advanced all the way. it might be too much advance. when you get the rattle when you let off to shift, then you went to far.
Reply #2November 16, 2009, 08:02:07 am
myke_w
  • 1099
« Reply #2 on: November 16, 2009, 08:02:07 am »
I'm surprised to see this question being asked.
Is there not a consensus on how much timing the 1.6 Bottom / 1.9 Top needs to run well?
I figured enough people have done this that there must be some data here to support running timing in at least a certain range.. no?
Reply #3November 16, 2009, 08:19:15 am
« Reply #3 on: November 16, 2009, 08:19:15 am »
seems like everyone has a different range. i remember a couple people building different 1.6/9 engines and they didnt have problems with advancement.
Reply #4November 16, 2009, 08:28:41 am
myke_w
  • 1099
« Reply #4 on: November 16, 2009, 08:28:41 am »
huh - mine worked ok with about 1.15mm of advance, It wouldn't start well cold or idle well but I think that was mostly because I had a 3 notch metal HG on a motor that could have used a 1 notch.
I was trying to drop compression, but that created other issues :( I would have guessed that running the same timing on a motor with the appropriate head gasket would have done much better. Also - I was running stock 1.6 TD nozzles in 1.6 injectors, I've gathered from folks that running the two stage 1.9 injectors might improve things a bit (reduce the marbly noises).
Reply #5November 16, 2009, 09:50:15 am
saurkraut
  • 904
« Reply #5 on: November 16, 2009, 09:50:15 am »
I'm at 1.19, but I have my injector break pressure set to 170 bar to overcome the possibility of secondary injection at high boost.  At 1.10 I was getting high EGT and water jacket temperatures, so I bumped to 1.19, and promptly pushed the head gasket out.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #6November 17, 2009, 01:50:00 am
  • 3468
« Reply #6 on: November 17, 2009, 01:50:00 am »
I know everyone runs different amount of advance and i was wondering what each their own sounded like.
There was a thread a while back about someone trying to get rid of the deafening rattle. Would you two agree that our half breed is exceptionally noisy?
EDIT: plus saurkraut, didn't see you there :P
Reply #7November 19, 2009, 08:37:55 pm
Powered by Spearco
  • 1203
« Reply #7 on: November 19, 2009, 08:37:55 pm »
Heres a short video of gauges when boosting.
Does any one elses run boost like this? The gauge is a dual boost and vacume. Boost on the right starts at  5, 10, 15, the red is 20.
I gotta get a higher gauge.
[url][IMG]
 :o
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #8November 19, 2009, 08:41:04 pm
  • 3468
« Reply #8 on: November 19, 2009, 08:41:04 pm »
LOLZ! i love the gauge on the left!
If boost is on the right what is on the left?
The right gauge looks like EGT and the left gauge looks like boost?
Reply #9November 19, 2009, 08:42:58 pm
catlin_cava
  • 1954
« Reply #9 on: November 19, 2009, 08:42:58 pm »
does your intake suck up little kids and small animals?
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #10November 19, 2009, 08:44:01 pm
  • 3468
« Reply #10 on: November 19, 2009, 08:44:01 pm »
So what's that? 30 psi?
what turbo are you running?
Reply #11November 19, 2009, 08:49:26 pm
Powered by Spearco
  • 1203
« Reply #11 on: November 19, 2009, 08:49:26 pm »
Boost on the left and EGT on right. The far left gauge seen at end of vid. is oil temp. Turbo is K24 and pump is an uber pump from Giles.
The turbo sees that boost level for only a second, and that was only second gear.
'13 Golf R:. Tuned
'98 Puch G320
Reply #12November 19, 2009, 08:51:11 pm
  • 3468
« Reply #12 on: November 19, 2009, 08:51:11 pm »
my fueling cuts off at about 22-25psi from my T3 :(
Which seems really reallly low to me...
Reply #13November 19, 2009, 08:57:03 pm
Powered by Spearco
  • 1203
« Reply #13 on: November 19, 2009, 08:57:03 pm »
I also ran that engine with a stock rebuilt TD pump and still saw way past the 15 psi on my gauge. I always get a grin when I look down and see it. Really need to get gauge that reads what I'm pushing.
I screwed the wastgate as close to closed as posable.
'13 Golf R:. Tuned
'98 Puch G320
Reply #14November 19, 2009, 09:11:20 pm
  • 3468
« Reply #14 on: November 19, 2009, 09:11:20 pm »
Hmmm. I removed my waste gate...
My boost pressures dropped a lot when i got rid of some restrictions i had on my intake and used slightly larger piping.
I'm rather disappointed with my boost numbers but i guess i'll see what happens with a big IC
