Author Topic: Painting Turbine housing and Exhaust Manifold  (Read 5025 times)
November 07, 2009, 01:17:44 pm
jack's lack
  • 275
« on: November 07, 2009, 01:17:44 pm »
Quick question, will the 1200º duplicolor high heat rattle can hold up if I spray my turbine housing and exhaust manifold with it?
Or should I just embrace the rust?
Thanks
1982 Rabbit diesel L 4 door
AAZ, K14, Giles pump, PD150 intake, P&P'd head, ceramic coated pistons, 2.5" stainless down pipe & exhaust. FK coils
My Build Thread
Reply #1November 07, 2009, 03:36:12 pm
kaneb
  • 164
    • www.dasdubbers.org
Re: Painting Turbine housing and Exhaust Manifold
« Reply #1 on: November 07, 2009, 03:36:12 pm »
Give it a shot what's the worst that can happen?
2004 Tdi sport-daily
1983 Rabbit TD-go kart
www.dasdubbers.org
Reply #2November 07, 2009, 04:40:19 pm
jack's lack
  • 275
« Reply #2 on: November 07, 2009, 04:40:19 pm »
Good point, if it burns off I will only be out a few bucks and a few minutes of my time, and I already have the paint.
My Build Thread
Reply #3November 07, 2009, 07:26:40 pm
GEE-BEE
  • 1604
« Reply #3 on: November 07, 2009, 07:26:40 pm »
NOPE CERAMIC COATING IS YOUR BEST OPTION ON THE EXHAUST, I DID THE HEAT SHEILD AND THE INTALE WITH SILVER POWDER COATING
Gpopshop does turbo housings in ceramic or polishing only...
Gee-Bee
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #4November 07, 2009, 07:46:47 pm
« Reply #4 on: November 07, 2009, 07:46:47 pm »
powder coat will take it.
The 1200 on the downpipe should hold up for a while as well.
Reply #5November 07, 2009, 08:50:16 pm
jack's lack
  • 275
« Reply #5 on: November 07, 2009, 08:50:16 pm »
Gee-Bee
2 problems there. 1. I can't get the turbo apart. there is one bolt that I can't get anything other than an open ended wrench on and it is too tight and just wants to round off. I went at it for weeks with the pb blaster and a torch but no movement, so I give up. 2. I have spent way more $$ than I should have on this project and I do not have a couple hundred extra to get these pieces ceramic coated as nice as that would be. So I am going on the cheap for now. Maybe if I have some the $$ in a year or so I will go ahead and get them coated, for now it's the rattle can or nothing.
I fear the same issues may prevail with powder coating as well, but I will look into it. thanks for the suggestion.
My Build Thread
Reply #6November 08, 2009, 12:33:05 am
« Reply #6 on: November 08, 2009, 12:33:05 am »
I rattle canned about the first foot of my DP a few months ago, now there's only about 6 inches of paint on it so it's getting burned off.........I think that paint is only for a couple seconds at a time of 1200F.
Reply #7November 08, 2009, 05:09:57 am
« Reply #7 on: November 08, 2009, 05:09:57 am »
I used BBQ paint for the manifold and turbine housing:
No long-term results yet.  It seems tough though, after painting it, I had to torch out one of the studs on the turbine housing, so sustained blasting directly from a torch didn't phase it.  I think the can said 1500*.
I did the downpipe with the 1700* stuff and torched it after it tacked up to "bake" it on.  We'll see how it holds.
Reply #8November 08, 2009, 05:18:01 am
« Reply #8 on: November 08, 2009, 05:18:01 am »
I didn't want to give all my secrets away, ;) but powder coating will hold up. I have a shop about 15 minutes away and asked them to do a header. He is Amish and cheap and really had no clue what would happen. He baked it a little hotter maybe longer and no issues. My friend at a truck garage does every single exhaust piece for the Kenworths in black powder coat with no problems either.
About Amish and cheap he did my friends 4 Honda rims for 40.00
Reply #9November 08, 2009, 05:20:14 am
« Reply #9 on: November 08, 2009, 05:20:14 am »
Amish powder coating, that just sounds wrong.  :)
I'll remember that though, I'll have some stuff that needs done before too long and I'm not too far away.
Reply #10November 08, 2009, 07:07:33 am
« Reply #10 on: November 08, 2009, 07:07:33 am »
paint just burns off. i used 1200* header paint, and it just burned off. my turbo is just as rusty now as it ever has been.
Reply #11November 08, 2009, 09:55:47 am
« Reply #11 on: November 08, 2009, 09:55:47 am »
I have used the 1,200 and the hotter ones...if they burn off it will usually be just a little closest to the exhaust ports. I always put mine in the oven and baked them like they said to do as well. If you can't get yours off of the turbo and bake I don't know what kind of results you may have.
Reply #12November 08, 2009, 05:18:52 pm
Syncroincity
  • 727
« Reply #12 on: November 08, 2009, 05:18:52 pm »
You may have better results if you bake the part for a few hours before in-car use... Spray the parts, let them dry fully, the cure in an oven for half a day. (and seeing as how you're building the engine in the kitchen, shouldn't be a problem ;D) Of course, if you can find an Amish powder coater in Georgia, I'd go that way.
How do you tell which Amish guy is the mechanic?
He's the one with his arm up the horse's bum... :D
*edt* Jeeze, I should really read all previous posts first, huh? :-*
I'd also recommend the turbo blanket insulator, keeps your under-hood temps down nicely, and hides the hi-temp paint when it does start to flake off... Find them on Ebay. Two layers, an inner wrap, and an outer reflective layer. You wrap the hot section and sort of stitch it closed with SS safety wire.
« Last Edit: November 08, 2009, 05:31:19 pm by Syncroincity »
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #13November 08, 2009, 07:14:42 pm
Black Smokin' Diesel
  • 656
« Reply #13 on: November 08, 2009, 07:14:42 pm »
Gee-Bee
I had that problem when taking appart a K24. Ended up grinding a 13mm wrench to make it fit.
The parts you are painting need to be rust free. Even if it can stand up to the heat, not many paints can stand up to rust. That means sandblasting. Painting over rust is a waste of money (except for por-15 or rustbullet but I doubt they have high temp paints).
