Author Topic: D24T power!!!  (Read 13927 times)
October 19, 2009, 07:57:28 pm
vwjunkie53
  • 98
    • The Volvo diesel forum
D24T power!!!
« on: October 19, 2009, 07:57:28 pm »
Hi folks,
just thought I would share a couple pics of my '84 volvo with the D24T six... Us D24 guys never get any love on the volvo forums, but I figured you guys would appreciate the setup.
Here are the mods: T3/T4 with a .50 a/r compressor housing, manual boost controller (running 15lbs boost for now) 3" turbo back exhaust, modified manifold with 2" mandral bent charge pipe, water/alcohol injection, and of course the pump has been "adjusted".  Its still running the 10mm head though.
Here are some pics and a link to a video so you can hear it:
http://www.youtube.com/user/vwjunkie53#p/a/u/0/o1dSIiqdgrM
1984 Volvo 760 GLE,  "built" D24T w/ARP studs, MLS head gasket, ported/polished head, 3 angle valve job, NA cam, 56mm T3/T4, NA manifold, FMIC w/ 3" alum piping, 3" turbo back, detailed in CAT yellow. T-5 manual swapped w/ Clutchnet 6-puck.  Best of 16.07@86mph with orig. worn out engine.
Reply #1October 19, 2009, 08:04:03 pm
Powered by Spearco
  • 1203
Re: D24T power!!!
« Reply #1 on: October 19, 2009, 08:04:03 pm »
Sounds bad a$$  8).
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #2October 19, 2009, 08:19:21 pm
Black Smokin' Diesel
  • 656
Re: D24T power!!!
« Reply #2 on: October 19, 2009, 08:19:21 pm »
So this thing has a 6 cyl turbodiesel and it's RWD uh? I want one :D :D
Reply #3October 19, 2009, 09:33:13 pm
OM617
Re: D24T power!!!
« Reply #3 on: October 19, 2009, 09:33:13 pm »
Very nice, but the air filter is far too small.
Reply #4October 20, 2009, 05:11:40 am
Re: D24T power!!!
« Reply #4 on: October 20, 2009, 05:11:40 am »
That air filter is fine. It will flow more than the gaint stock paper element.
Very nice build.
Reply #5October 20, 2009, 05:14:35 am
vwjunkie53
  • 98
Re: D24T power!!!
« Reply #5 on: October 20, 2009, 05:14:35 am »
Thanks,
the air filter was a freebee from a friend.  I'm going to build a nice air box for it and get a better filter.  However that one does have he inverted cone in the top so there is a decent amount of filter area.
Jason
Reply #6October 20, 2009, 08:01:19 am
Re: D24T power!!!
« Reply #6 on: October 20, 2009, 08:01:19 am »
i still want one. but not in a volvo. too heavy.
Reply #7October 20, 2009, 12:48:47 pm
Re: D24T power!!!
« Reply #7 on: October 20, 2009, 12:48:47 pm »
I love it.  You know, I was in the hunt for a nice early 242GT to swap in a B24T, but this Corrado came along and I couldn't pass it up.
Early Volvo's aren't that heavy.  242 turbo's weighed about 3100 lbs, 245T's weighed about 3400 fully loaded.
Reply #8October 20, 2009, 02:36:47 pm
dennis
  • 311
Re: D24T power!!!
« Reply #8 on: October 20, 2009, 02:36:47 pm »
Hi folks,
I have an 83 245 D24. Just located a 200k mile D24T for $750.00 shipped to my door. Just need to sell some stuff. 80 horses in a wagon is not a lot of fun. As soo as I get my Caddy on the road Im gonna get the Volvo done. Your setup is very nice. Getting a woody.
Dennis
« Last Edit: October 20, 2009, 02:38:57 pm by dennis »
1980 Caddy TD (Always in progress)
1983 Volvo 245 D24 NA Building D24T
1980 Air-cooled Westy
1956 F100 (What to do???))
Reply #9October 20, 2009, 05:05:34 pm
410
  • 581
Re: D24T power!!!
« Reply #9 on: October 20, 2009, 05:05:34 pm »
A nice big intercooler in the grill would finish things off nicely.  What a sweet sound!
Reply #10October 20, 2009, 06:36:55 pm
jack's lack
  • 275
Re: D24T power!!!
« Reply #10 on: October 20, 2009, 06:36:55 pm »
YES
that sounds amazing
I'm with Roids on the weight 2,000# rabbit < 3,000# volvo, a lot less ;).
someone please put one in a rabbit
1982 Rabbit diesel L 4 door
AAZ, K14, Giles pump, PD150 intake, P&P'd head, ceramic coated pistons, 2.5" stainless down pipe & exhaust. FK coils
My Build Thread
Reply #11October 21, 2009, 06:28:04 am
vwjunkie53
  • 98
Re: D24T power!!!
« Reply #11 on: October 21, 2009, 06:28:04 am »
I don't know about a rabbit, but maybe a jetta or something.  I had actually thought about it, but man the volvo is really a nice car!  Its more confortable, rides better, is quieter, and is just overall nicer than a golf or jetta.  Not knocking them I have had a few of them.  Honestly I couldn't have cared less about the car I just wanted it because of the engine, but ended up really liking the car.  Also have a turbo diesel thats rear wheel drive is a hell of alot more fun...  I originally found a video on Youtube of a TD volvo and the sound was what made me want one. Sounds like a cummins turbo diesel.  I have had a few 1.6 TDs and adding two more cylinders to it makes it that much more fun.  Even with how big it is and what it weighs, its probably good for low 15s to high 14s with only the 15lbs of boost I'm running.  When I get the head studs in we are really going to see what it can do.  At this point, I haven't even removed the collar on the fuel screw!  There is alot left in it!
Thanks for all the compliments
Jason
Reply #12October 21, 2009, 10:43:56 am
Re: D24T power!!!
« Reply #12 on: October 21, 2009, 10:43:56 am »
Jason
hmm. the difference of a jetta and a rabbit? the trunk... the front half of the cars are exactly the same. Mk1 Jettas and rabbits had tons of (most of) the same pieces. Mk2's were the same. golfs and jettas were pretty much the same car, but with a trunk instead of a hatch.
and like you, i ended up buying a non-vw for the engine. i paid 250 bucks for my Audi 5000 TD just for the engine, and it turns out the car isnt as bad as i thought it was. you are right, its nice having way more room in it. and the interior is way more plush than a rabbit or jetta. its alot wider and longer than a rabbit/jetta also. i bet your volvo and my audi are about the same size. my car weighs 2800 or something like that. ive got my engine turned up to about 20 psi with the collar intact on the pump. it smokes a little bit when you get on it, but is quickly cleared up once you hit boost. the trans is about gone tho, so its not that fast, but it pulls like a mother for a 5000, in my oppinion. when i drove it home, it was a 500 mile trip with about 3 psi of boost. 3 of the 5 manifold gaskets were blown out. BAD. i almost thought it had an injector knock or really bad piston slap when i got it, but it was just a really really bad exhaust leak. rest of the exhaust system was perfect, kinda felt bad cutting it up, but not really at the same time.
Reply #13October 21, 2009, 04:59:11 pm
vwjunkie53
  • 98
Re: D24T power!!!
« Reply #13 on: October 21, 2009, 04:59:11 pm »
I was thinking more of a '85 or newer jetta.  The cars came quite a way when they went to the A2 chassis.  I don't think a rabbit could hold up the engine.  The D24T is very heavy, in fact the volvo diesels came with different front springs to hold the weight!
I would guess a Audi diesel is about as rare as my volvo, at least in the midwest anyway.  I have never seen another volvo diesel, ever... The same goes for an audi diesel.  There just aren't any around.
Jason
Reply #14October 21, 2009, 05:04:06 pm
Re: D24T power!!!
« Reply #14 on: October 21, 2009, 05:04:06 pm »
i have seen 2 TD Audis in my life. one for sale on craigslist. white, pristene, cracked head.
and a gold one for sale on craigslist. not so pristene. but it ran. and it was 250 bucks. SOLD! so now i own it...
ive only seen one Volvo TD, and one BMW TD also. they are pretty rare i think.  a diesel benz is extremely common tho.
