Author Topic: T3 VW and Mercedes Hybrid Turbocharger  (Read 11637 times)
Reply #15October 13, 2009, 10:46:20 pm
monomer
  • 414
Re: T3 VW and Mercedes Hybrid Turbocharger
« Reply #15 on: October 13, 2009, 10:46:20 pm »
almost makes me want to rebuild the t3 from my 300d.
it needs a new center section and wheels, though
www.michiganvw.org
Reply #16October 14, 2009, 09:06:09 am
« Reply #16 on: October 14, 2009, 09:06:09 am »
only 8 in first gear? ive always had over 15 in every gear. even when i had my gay low geared 4 speed. i make about 25 psi with my VNT between shifts. finally pegged my 30 psi gauge last night, and i didnt blow the intercooler apart like everyone told me i would. its a stock volvo unit.
Reply #17October 14, 2009, 06:53:15 pm
Chestrockwell
  • 95
« Reply #17 on: October 14, 2009, 06:53:15 pm »
8 in 1st with the stock T3. Now it's about 18 in 1st.
Reply #18January 14, 2010, 11:02:46 pm
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #18 on: January 14, 2010, 11:02:46 pm »
with my old T2 i could make 20psi in first, now i struggle to make 10. 15 in second, 18-19 in 3rd, and more than 20 in 4th and 5th.
i wonder if its a bad idea to swap the prothe Merc T3 compressor wheel and housing onto my newly rebuilt 1.6TD T3..... the prother compressor wheel looks nice enough and so does the housing - plus the compressor wheel is the lightest part of the rot/assy.
'91 Golf Cabrio 1.9TD
Reply #19January 15, 2010, 08:49:23 am
« Reply #19 on: January 15, 2010, 08:49:23 am »
but there could be casting defects that are not detected by the naked eye. i would see if everything balances up. if you can get that wheel to balance on your shaft, you should be fine.
Reply #20January 15, 2010, 06:22:31 pm
foxracer1
  • 991
« Reply #20 on: January 15, 2010, 06:22:31 pm »
Do you have measurements of the vw comp wheel vs merc wheel, and vw turbine wheel vs merc wheel?
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #21January 16, 2010, 11:09:13 am
subsonic
  • 1836
« Reply #21 on: January 16, 2010, 11:09:13 am »
related pics.
Reply #22January 16, 2010, 02:50:09 pm
monomer
  • 414
« Reply #22 on: January 16, 2010, 02:50:09 pm »
What year range/series/engine size does that MB turbo used on ? I'd like to hunt one or two.
That's a 300 series turbo (300 SD, 300TDT) from the early 80s.  I've got one one the shelf in the garage If someone's interested.  It's in fine shape and functioned perfectly when on the car, but was removed for a VNT installation.  PM...
all 300D's since w115s are turbo. starts in 1979 in America (w123 were the first turbo diesels)
240's are n/a, and 190D's are n/a.
www.michiganvw.org
Reply #23January 16, 2010, 05:29:42 pm
foxracer1
  • 991
« Reply #23 on: January 16, 2010, 05:29:42 pm »
I've been playing with measurements. a friend measured my t3 wheel and i thought he said it measured as a 35 trim. I've heard the merc charger is a 50 trim. I've been mapping my engine combo on various maps and the 50 trim looks the best.
I wondered how different the turbine was from the stock vw turbo. I don't wanna lose any spool down low but would like to play around with maybe getting some better flow up top.
I did some pump rebuilding in trade for a merc t3 so when he finds a merc t3 its mine to play with.
91 S10 305 TPI T56
Reply #24January 17, 2010, 08:46:32 pm
subsonic
  • 1836
« Reply #24 on: January 17, 2010, 08:46:32 pm »
I thought our t3 was a wierdo 42 trim?
Reply #25January 17, 2010, 08:54:10 pm
foxracer1
  • 991
« Reply #25 on: January 17, 2010, 08:54:10 pm »
I need to double check i didn't measure it my self so i can't claim 100% accuracy.
91 S10 305 TPI T56
Reply #26January 18, 2010, 12:35:32 am
OM617
« Reply #26 on: January 18, 2010, 12:35:32 am »
Incorrect. Only 1982-1985 models are turbo. 1975-1981 are non-turbo.
related pics.
The OM617 uses a 45 trim compressor, not 50.
Reply #27January 18, 2010, 03:29:48 am
gldgti
  • 488
« Reply #27 on: January 18, 2010, 03:29:48 am »
....and, i thought after measuring the stock vw T3 that it might be a .38 trim.... hahahaha!
Reply #28January 18, 2010, 12:33:33 pm
foxracer1
  • 991
« Reply #28 on: January 18, 2010, 12:33:33 pm »
related pics.
So what years/models have a 50 trim compressor?
91 S10 305 TPI T56
Reply #29January 18, 2010, 03:41:49 pm
monomer
  • 414
« Reply #29 on: January 18, 2010, 03:41:49 pm »
crap, forgot about the couple of years of w123 n/a's.
300D W124's also had a T3, I have one sitting out in the garage. Looks to be a little smaller then a 50 trim.
www.michiganvw.org
