Author Topic: boost on 4D55T engine  (Read 7836 times)
October 03, 2005, 09:23:12 am
zyewdall
  • 393
« on: October 03, 2005, 09:23:12 am »
I finally installed a boost gauge on my Mitsubishi truck, and it never seems to get above 10psi.    Just wondering if anyone else has seen otherwise, or knows if this is normal.
Zeke
'89 Subaru 4x4 touring wagon
1976 Ford Sasquatch pickup
Reply #1October 03, 2005, 09:31:01 am
Maarten
  • 339
« Reply #1 on: October 03, 2005, 09:31:01 am »
10psi could be the stock boostsetting.. (seems normal to me)
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #2October 04, 2005, 09:02:34 am
Master ACiD
  • 328
« Reply #2 on: October 04, 2005, 09:02:34 am »
could the exhaust be overly restrictive? how about the intake?  maybe the boost enrichment isnt functioning?
Reply #3October 04, 2005, 01:00:15 pm
zyewdall
  • 393
« Reply #3 on: October 04, 2005, 01:00:15 pm »
Quote from: "Master ACiD"
The whole intake system doesn't look very big for a 2.3l engine -- I would expect larger diameter tubing and such on a diesel.  But I don't really know.  what is the expected boost on a stock 1.6TD setup (if there is such a thing as stock?).  I read alot of threads talking about 14psi or so, but those may be modified ones?
I haven't tested to see if the boost enrichment is functioning, but it seems to have plenty of power when the boost pressure starts going up which implies that it does.  Maybe there should be more?  One thing is that I also did which could be affecting it was I turned the fuel screw down to where it doesn't produce any visible smoke even at WOT (running B100).
