Author Topic: Diesel fuel line  (Read 3145 times)
September 28, 2009, 08:21:25 am
calituner
  • 12
Diesel fuel line
« on: September 28, 2009, 08:21:25 am »
im replacing the lines on my 80 caddy. i need to know what fuel lines to use to go from the tank to the metal hard lines. i have acces to standard rubber gas fuel hose, transmission cooler hose which is thicker walled, and standard gas fuel injection hose. is it safe to use the standard gas fuel line or will the diesel eat it up? im not planning on a veggie diesel or running biodiesel anytime soon. but i cant find an answer to my question... Is using gas fuel line from say... pepboys safe to use with diesel fuel
Reply #1September 28, 2009, 08:50:17 am
GEE-BEE
  • 1604
Re: Diesel fuel line
« Reply #1 on: September 28, 2009, 08:50:17 am »
yes no problem...
I removed my fuel pump and acumalatlor and used those lines and cutoff one end and replaced it with a barb fitting for the swap on my fuel tank lines.
I have a 81 gas caddy that Iam just finsihing the AAZ swap
Give a call if you need help, office 800-556-3160
Iam in H.B. ( O.C. )
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2September 28, 2009, 09:00:57 am
arb
« Reply #2 on: September 28, 2009, 09:00:57 am »
I used coated 5/16" brake lines and Goodyear fuel line. Works well and vill stand up to the chemicals.
Reply #3September 28, 2009, 09:08:04 am
calituner
  • 12
« Reply #3 on: September 28, 2009, 09:08:04 am »
i also noticed the metal lines are 5/16 but on the tank one is 5/16 and other looks to be 3/8. no problems with 5/16 all around?
Reply #4September 28, 2009, 09:11:27 am
arb
« Reply #4 on: September 28, 2009, 09:11:27 am »
I think you're right... Thinking back, I think the 5/16" was my return line and the supply was 3/8" :-)
Reply #5September 28, 2009, 09:19:08 am
calituner
  • 12
« Reply #5 on: September 28, 2009, 09:19:08 am »
ugh then why didnt vw make the metal hard lines to the pump 3/8th aswell.  ???
oh well.  ill snake some 5/16 and 3/8 line from work and start her up.
i has having a problam with no fuel. the return line i could blow air into... but the supply wasnt getting fuel and actually was creating vacuum in the supply line. i could see fuel go into the IP but when i stopped cranking it sucked in back into the fuel filter. im thinking the PO had tank lines mixed up. or maybe i had lines mixed at under hood point. i removed fuel cap so i know its not faulty tank ventallation. does the return line in the tank have a check valve? or could it be that the baffle has come loose and is blocking the supply line?
« Last Edit: September 28, 2009, 12:11:14 pm by calituner »
Reply #6September 28, 2009, 05:55:32 pm
calituner
  • 12
« Reply #6 on: September 28, 2009, 05:55:32 pm »
no input?
Reply #7September 28, 2009, 09:20:46 pm
lovinthedeez
  • 489
« Reply #7 on: September 28, 2009, 09:20:46 pm »
sounds like there is air in your lines.  one time when the little seal fell on the ground to my fuel filter during a change, I tried to bleed the air out of it for days. Air kept going back UP ??? the line towards the air filter.  found the gasket on the ground, put it on there (where it screws on), and BAM.  It bled right out.  check the lines to make sure the connections are all real good and tight.
Reply #8September 29, 2009, 03:38:03 am
truckoSaurus08
  • 65
« Reply #8 on: September 29, 2009, 03:38:03 am »
The rubber hoses that come off the tank to the metal lines are both metric I.D. .But you can get away with it by using standard size fuel line. Gas fuel line is ok. That's what I used. 8)
Reply #9September 29, 2009, 04:20:46 am
arb
« Reply #9 on: September 29, 2009, 04:20:46 am »
You might want to double clamp where the metric meets the US... with extra force on the last clamp. I have never seen a check valve in the tank other than the fill tube on newer models.
Reply #10September 29, 2009, 07:57:12 am
calituner
  • 12
« Reply #10 on: September 29, 2009, 07:57:12 am »
well last night i hooked up the fuel lines. poured back the red diesel that was in the tank back in just to see if it worked... It did, she rumbled to life but damn even with fresh motormounts all around itll rattle the bolts off everything. i did a timing belt but didnt have the dial indicator to set the IP timing. could this possibly be my issue? i havent really checked oput the basics like compression and stuff like i should. i probably should have since i swapped the engine from the rabbit to my caddy
Reply #11September 29, 2009, 08:24:43 am
arb
« Reply #11 on: September 29, 2009, 08:24:43 am »
Absolutely a rough idle when warm can be timing... The tool can be had for about $50 on ebay and elsewhere. Or, pay someone to do it.
Reply #12September 29, 2009, 06:18:32 pm
Rabbit TD
  • 840
« Reply #12 on: September 29, 2009, 06:18:32 pm »
  If you like tinkering with these things you definately need to get an indicator and a compression gauge.  Without them it's all guess work and usualy the wrong guess too ???  You can get avery good compression gauge at Harbour Freight for less than $30 for a set with different adapters for different engines and they work fine.  I've had mine for almost 20 years that I got from them and I saw the set advertised this past Spring for $29.  From what I remember that's what I gave 20 years ago and it didn't come with all the adapters this current one does.  It's not Snap-On but I'm not working on the Space Shutte either ;D
Reply #13September 30, 2009, 07:57:32 am
calituner
  • 12
« Reply #13 on: September 30, 2009, 07:57:32 am »
well a customer bought me a diesel compression tester as we figured we where gonna do a compression test on his 7.3 ford. and i sacked it up and bought the timing belt tool kit from baum tools thru my snapon guy. that lets me do vw and audi timing belts gas and diesel for 4cyl from like 70s to 2005. even came with the timing chain tensioner tool for the 1.8t and 2.8 v6 that i borrowed from my friend that used to work for vw. its a handy kit. just doesnt have a dial indicator for IP timing
