well, got it running, and home!
took a bit of fiddling to get it started, as the starter had gotten some water in it apparently, as it would not turn the motor over at all, but a half an hour in a heated garage fixed that.
while I was waiting for the starter to thaw, I installed the drivers seat out of our mk3 parts jetta(took a little imaginative work with a grinder and a few bolts) and it is soooooo much better than the hammered seat that was in it.
once that was done, I fired it up(after fiddling with the timing a bit) and took it for a test drive!
some video here too!(super crappy camera vids, there will be better to come)
starting(not the first start, but still a nice sound to hear!)
[and a ride along(pretty long, but shows how well it runs)
the "blowby" on the windshield turned out to be oil leaking from the supercharger feed line getting caught by the wind, not a bad leak, but something I will have to attend to at some point.
it pulls hard, holds oil pressure, and the water temps are pretty steady at about 180*(more if you flog it, less coasting downhill, but not by much)
had to leave the hood off for the moment, because the supercharger wanted to smack it when accelerating, I think I can cut some of the reinforcement out of it above the supercharger(leaving just the hood skin) and that will make it clear.
then I got to abuse the fresh motor by driving it for an hour on the highway.
I did my best to vary engine speed and load, but there is only so much you can do in traffic that really wants to go 65MPH.
at 65MPH cruise, it made about 8PSI of boost, held water temps of just under 180*, oil pressure at 75PSI and EGT of 550*
flogging it up a long hill(foot to the floor) at 65MPH I saw 950* EGT, so I think it can survive lots more fuel.
no smoke out the exhaust all the way home, but the little oil leak covered the windshield pretty good by the time I got home.
it is clear, by watching the motor move around, that I am in need of new motor mounts, the passenger rear one is moving much more than I will like, but I can work on getting the details figured out now that it is back on the road!
-Owen
