Author Topic: Building a glow plug HOW-TO and need a couple of MK1 and MK2 pictures...  (Read 10801 times)
Reply #15September 27, 2009, 11:39:53 pm
lovinthedeez
  • 489
Re: Building a glow plug HOW-TO and need a couple of MK1 and MK2 pictures...
« Reply #15 on: September 27, 2009, 11:39:53 pm »
oh yeah, just wanted to say that the wire that should go from the glow plug relay to the coolant temp sensor (which I don't have ::)) should be blue/white; as per the bentley.  saw the XXXX, but I don't think it changed for mk1's
Reply #16September 28, 2009, 06:41:28 pm
macka
  • 957
« Reply #16 on: September 28, 2009, 06:41:28 pm »
I can get a pic of the plastic plug and the mark 2 fuse panel in the AM
Quote from: Vincent Walden
Reply #17September 28, 2009, 07:35:16 pm
dieselherb1
  • 354
« Reply #17 on: September 28, 2009, 07:35:16 pm »
What, no pics of Mk1s?
Reply #18September 28, 2009, 07:48:56 pm
Jettage1
  • 202
    Past VWs: 80 Scirocco S, 90 GTI, 00 Passat GLX
« Reply #18 on: September 28, 2009, 07:48:56 pm »
Very timely, Vince.  I've just been dabbling with disconnecting my coolant temp sensor to see how it affects my GP performance.  Which leads to one comment on your writeup:  On your Step 3 in troubleshooting, you talk about disconnecting the sensor and then the relay should run for 20 sec.  You then say that if it does, the relay is good.  I assume you are also implying that the sensor is therefore bad?  Might be good to state it explicitly.
Also, would you want to include the collected wisdom about fast / slow glows and relays here?  Maybe the relay numbers and the GP numbers?  I know this has appeared in a number of posts over time, and since your How To's end up being frequently referred to, maybe this would be an appropriate place to capture the info.
Lastly, maybe some simple suggestions for those wanting to wire up a separate GP indicator dash light...
Thanks again for all your work!
Steve
92 Jetta EcoDiesel
     pumped by Giles...powered by Frybrid...functional by dumb luck
Reply #19September 28, 2009, 07:55:43 pm
« Reply #19 on: September 28, 2009, 07:55:43 pm »
Great suggestions... some of which I'd thought of, some of which... not so much!!
In particular, I'm planning to add a step detailing how to double-check the coolant sensor with a multimeter.
Will add your thoughts in... thanks again!
Reply #20September 28, 2009, 07:56:52 pm
« Reply #20 on: September 28, 2009, 07:56:52 pm »
For the most part the MK1 setup is the same as an MK2, but if you notice any big differences holler and I'll update... I don't have an MK1 in the fleet at the moment. :'(
Reply #21September 28, 2009, 08:36:35 pm
macka
  • 957
« Reply #21 on: September 28, 2009, 08:36:35 pm »
that's a good idea
Reply #22September 29, 2009, 08:39:49 am
gigaz2
  • 626
« Reply #22 on: September 29, 2009, 08:39:49 am »
are these any good for you?
I guess the relay is a replacement part
Reply #23September 29, 2009, 08:02:17 pm
« Reply #23 on: September 29, 2009, 08:02:17 pm »
Those are good pictures gigaz2... are they from a Rabbit per chance?
Reply #24September 30, 2009, 03:20:19 am
gigaz2
  • 626
« Reply #24 on: September 30, 2009, 03:20:19 am »
nop, 1983 mk2 golf C, manufactured on 10/1983 in the wolfsburg factory
Reply #25September 30, 2009, 04:18:30 am
macka
  • 957
« Reply #25 on: September 30, 2009, 04:18:30 am »
nice
Reply #26August 28, 2010, 07:53:07 am
« Reply #26 on: August 28, 2010, 07:53:07 am »
I am getting ready to fire up the car. There is the flange with the 2 pronged sensor for glowplugs I believe and I can't find a free wire to go to it. It is MKII 86 jetta. I just wonder if I hooked something else to it. All explination of the coolant flange sensors would be helpful.
PS I looked at vince's page he was making from this already. It said green wires go to it, but I can't find any  ???
Reply #27August 29, 2010, 06:45:55 pm
« Reply #27 on: August 29, 2010, 06:45:55 pm »
I think I figured it out. I am using a different coolant flange and I had the old one marked I think with green tape. I have the one connector marked with green tape. I will just have to find where the old flange is.
Would that disable the heater fan from working? I am having some trouble with that. I replaced the resistor when I did everything else and it should at least have full power at the highest setting even if the new resistor was bad out of the box.
Need help as I won't put this together until I figure out the heater fan.
Reply #28August 30, 2010, 09:10:47 am
« Reply #28 on: August 30, 2010, 09:10:47 am »
they switched to mk2 earlier than the us? and wouldnt your car be an 84 since its a very late 83 manufacture date?
Reply #29September 01, 2010, 11:17:30 am
