Author Topic: 1.6TD engine blocks: compatibility  (Read 4166 times)
September 30, 2005, 10:19:21 am
neich
  • 28
« on: September 30, 2005, 10:19:21 am »
Hi,
A friend of mine has broke his Vanagon engine, the 1.6TD JX (51kW).  We suspect that some rod has broken and then maybe we just have to find a used to block to swap it. I have begun to look at different 1.6TD engines and I have found that there is a lot of choice, but I am not sure if all of them are just "bolt on".
There are five 1.6TD engines: JR (51kW) MF (51kW) RA (59kW)  SB (59kW) CY (51kW)
Can I use any of the these as far as I only consider the block ?
Thanks
Nacho
P.D. I know the oil pan and oil pump is different from the JX to the others, but those parts can be also swaped from the broken JX to the other, I guess.
Reply #1September 30, 2005, 11:49:05 am
vwmike
  • 1158
« Reply #1 on: September 30, 2005, 11:49:05 am »
Not all of those engines will work as some (the CY - maybe others) are solid lifter and the others ought to be hydraulic lifter. I don't know if the head on the JX engine is solid or hydraulic lifter either though.
Reply #2October 02, 2005, 02:35:36 pm
Baxter
« Reply #2 on: October 02, 2005, 02:35:36 pm »
JX is solid.
I may have a spare JX block if needed, ready for a rebuid but better than one with a leg out of bed.
Reply #3October 06, 2005, 08:49:08 am
neich
  • 28
« Reply #3 on: October 06, 2005, 08:49:08 am »
Thanks for the answers, I thought that JX had hydraulic lifters so it is great to know I am wrong ! How do you tell "visually" that a head has solid or hydraulic lifters ?
I think that I will search for a used one in good condition since the one that has blown it was a fresh rebuild (and expensive) one !! And it had only three years ... :-(
Then the questions is, which other VW 1.6TD engines have solid lifters and then are compatible with the JX engine ?
BTW, the engine broke because the crank "slipped" with respect to the distibution pinion, so you can image what happened to valvles and pistons.
Thanks again
Nacho
Reply #4October 07, 2005, 01:32:08 am
neich
  • 28
« Reply #4 on: October 07, 2005, 01:32:08 am »
Great !! That's exactly what I need.
Thanks
Nacho
Reply #5October 07, 2005, 04:55:20 am
Audi80
« Reply #5 on: October 07, 2005, 04:55:20 am »
I have seen a aftermarket mech head that had the bump for oil return hole, but did not have hole drilled. We bought wrong head gasket for it :(
