Author Topic: t2 turbo indexing  (Read 2619 times)
August 07, 2009, 12:31:17 pm
skifree
  • 32
t2 turbo indexing
« on: August 07, 2009, 12:31:17 pm »
I have a t2 turbo and need to change drain and feed position about 30 degrees.Is it possible to move just the center section of the turbo?
Reply #1August 07, 2009, 02:33:29 pm
Re: t2 turbo indexing
« Reply #1 on: August 07, 2009, 02:33:29 pm »
yes. but you will have to re bend all the lines to fit the new clock position.
Reply #2August 07, 2009, 02:45:03 pm
skifree
  • 32
« Reply #2 on: August 07, 2009, 02:45:03 pm »
I should have said how instead.
Reply #3August 08, 2009, 09:13:46 am
« Reply #3 on: August 08, 2009, 09:13:46 am »
loosen the 6 bolts on the hot side, and the 6 bolts on the cold side, then rotate the center section where you need it. look up how to rebuild the turbo. it will tell you how to get it apart at least, and re clocking it is super easy if you can get it apart.
Reply #4August 08, 2009, 05:53:43 pm
Rabbit TD
  • 840
« Reply #4 on: August 08, 2009, 05:53:43 pm »
Are there any gaskets in there that will need to be replaced when that is done.
Reply #5August 09, 2009, 11:00:15 am
« Reply #5 on: August 09, 2009, 11:00:15 am »
no, not if you are careful. there should be an o-ring around the cold side, but that shouldnt break.
