Author Topic: "electric" aaz pump...want to simplify!  (Read 10848 times)
Reply #15August 07, 2009, 07:27:26 am
Re: "electric" aaz pump...want to simplify!
« Reply #15 on: August 07, 2009, 07:27:26 am »
AAZ pumps are not kosher. :(
Just to be clear... VW used many different versions of Bosch pumps on the AAZ engine... only one of which is the "eco" version that has no LDA and a small cam plate.  ;)
Reply #16August 07, 2009, 09:28:59 am
jack's lack
  • 275
« Reply #16 on: August 07, 2009, 09:28:59 am »
Turns out I like you and Jerry, have the same eco/non LDA pump. When I first saw this thread, I was like hey that looks just like my pump, and when I saw Andrew's reply I was like string of expletives that will not be repeated for the sake of this forum. However also like Jerry, my pump is in the hands of a man named Giles, yes it is pricey, but a good solution to this problem. ;D
at least we are not alone, misery loves company right? eco pump fail :(
Good luck
1982 Rabbit diesel L 4 door
AAZ, K14, Giles pump, PD150 intake, P&P'd head, ceramic coated pistons, 2.5" stainless down pipe & exhaust. FK coils
My Build Thread
Reply #17August 07, 2009, 11:09:00 am
carrizog60
  • 978
« Reply #17 on: August 07, 2009, 11:09:00 am »
My incentive for posting certainly wasn't in order to create strings of expletives, but the fake pump's flat LDA cover is a dead giveaway.
is the smaller cam plate a big thing?
is it smaller then 1.6?
if i could i would like to keep and tune this pump as it has less miles than the 1.6 gtd one...
Portugal
Reply #18August 08, 2009, 10:02:53 pm
hippiekiller
  • 73
« Reply #18 on: August 08, 2009, 10:02:53 pm »
so.., on an  aaz pump with the 'straight gauge' LDA does one need to replace the small pin that rides on the 'cone' as well when doing the diaphram swap, or is it a simple exchange (except for the previously mentioned ...fulcrum for part of the control collar lever assembly..and i'm guessing the starwheel?
95 jetta, 2"lift
92 dodge diesel too much to list
Reply #19August 10, 2009, 12:22:09 am
carrizog60
  • 978
« Reply #19 on: August 10, 2009, 12:22:09 am »
can you show me a pic of this?
and remove the rod that the control collar rides against.
Portugal
Reply #20August 11, 2009, 12:35:35 am
carrizog60
  • 978
« Reply #20 on: August 11, 2009, 12:35:35 am »
It is the longer metal rod poking down from the top of the picture and aimed directly at the black governor shaft.
thanks
it doesnt look to do nothing...whats is function in there?
Portugal
Reply #21August 11, 2009, 09:32:33 am
« Reply #21 on: August 11, 2009, 09:32:33 am »
the fuel collar lever hits it and limits fuel. if you take that black flat piece sticking up directly behind the governor, and push it towards the front of the pump, it will hit that pin, and limit the fuel. you need to get rid of the pin or you basically have a n/a pump.
Reply #22August 11, 2009, 11:31:15 am
carrizog60
  • 978
« Reply #22 on: August 11, 2009, 11:31:15 am »
is it possible to do that with the pump on place?
Portugal
Reply #23August 11, 2009, 12:23:07 pm
Hey
  • 339
« Reply #23 on: August 11, 2009, 12:23:07 pm »
It won't work too well if you don't swap the advance system and regulator. from your old pump.
Reply #24August 11, 2009, 10:35:34 pm
« Reply #24 on: August 11, 2009, 10:35:34 pm »
i backed my pin out till it was flush with the inside of the pump and epoxied it around the outside. doesnt leak.
Reply #25August 12, 2009, 02:09:58 pm
gigaz2
  • 626
« Reply #25 on: August 12, 2009, 02:09:58 pm »
why don't you just swap the old pump to this engine?
the Bosch seal kit costs ~13€  ;)
Reply #26August 13, 2009, 10:59:33 am
carrizog60
  • 978
« Reply #26 on: August 13, 2009, 10:59:33 am »
if i could do the trick with this and with the parts of a damaged 1.6 i have i could sell the good gtd pump i have...
also, this pump looks mint and has low km so respecting to wear wins by far the gtd one...
Portugal
Reply #27August 14, 2009, 03:34:06 pm
carrizog60
  • 978
« Reply #27 on: August 14, 2009, 03:34:06 pm »
just for kicks, my pump doesnt have the number 4 connector shown in the "make 1.9 faster" topic...
Portugal
