Author Topic: "electric" aaz pump...want to simplify!  (Read 10832 times)
August 01, 2009, 04:20:26 am
carrizog60
  • 978
« on: August 01, 2009, 04:20:26 am »
hello
just bought a 1.9td passat 35i due to my golf gtd was totaled...
this aaz pump has electrical stuff that i dont want to deal with...
i have a spare damaged 1.6gtd pump,could i swap the lda top and just delete the electrical stuff?
or is not that simple?
just want to tune this pump the way i had in the golf and keep it simple...
Portugal
Reply #1August 01, 2009, 07:57:02 am
Re: "electric" aaz pump...want to simplify!
« Reply #1 on: August 01, 2009, 07:57:02 am »
If you can post some pictures I think that would be really helpful... there were many different configurations of electric dohickies on AAZ pumps in different parts of the world as the pump design evolved towards the TDI version, some of which can be safely removed and some of which need to hang around.
Reply #2August 01, 2009, 03:32:14 pm
carrizog60
  • 978
« Reply #2 on: August 01, 2009, 03:32:14 pm »
tomorrow will snap some.
it also have egr,will ditch that too ::)
Portugal
Reply #3August 02, 2009, 05:08:40 am
carrizog60
  • 978
« Reply #3 on: August 02, 2009, 05:08:40 am »
here they go:
Portugal
Reply #4August 03, 2009, 12:22:27 am
carrizog60
  • 978
« Reply #4 on: August 03, 2009, 12:22:27 am »
Cant just swap pump tops?this pump looks nice and clean,shame to ditch that...
Portugal
Reply #5August 04, 2009, 06:48:14 pm
dieselherb1
  • 354
« Reply #5 on: August 04, 2009, 06:48:14 pm »
Okay please explain what this pump is and what parts need to make it suitable on a TDI.
Thanks
Reply #6August 04, 2009, 06:59:45 pm
dieselherb1
  • 354
« Reply #6 on: August 04, 2009, 06:59:45 pm »
I have similar to this one but with a domed top with pressure line. But it has electric lines on it too. Is the electric needed(other than solenoid ofcourse)?
Reply #7August 05, 2009, 12:15:48 am
carrizog60
  • 978
« Reply #7 on: August 05, 2009, 12:15:48 am »
Yes, you could, but you'd need to pull the extra pin that is present in the non-lda pumps.
Andrew
what pin?
Portugal
Reply #8August 05, 2009, 07:47:18 am
« Reply #8 on: August 05, 2009, 07:47:18 am »
Andrew
what pin?
there is a fuel limiting pin in the side of the pump that only lets it deliver so much fuel. you need to grind it off, or just drill the outisde and walk it out with vise grips. its hardened steel by the way, so you will need to grind it, not cut it.
Reply #9August 05, 2009, 08:17:06 am
jiggs
  • 41
« Reply #9 on: August 05, 2009, 08:17:06 am »
that electronic switch just sends a signal to open or close the EGR vacuum valve...
swap it all ;)
or just swap the LDA pin!
Dark Projects...
Mecānica Auto e Performance...
Reply #10August 05, 2009, 10:56:10 am
carrizog60
  • 978
« Reply #10 on: August 05, 2009, 10:56:10 am »
swap it all ;)
yes, i know what it is but i didn't knew if i could securely remove it without any bugs...electronic stuff kinda scares me....
tonight i am going to open the lid(i didn't have the tools to remove the screws) and see what is going on inside...
Portugal
Reply #11August 05, 2009, 06:28:56 pm
jiggs
  • 41
« Reply #11 on: August 05, 2009, 06:28:56 pm »
well then, just take it apart! no bugs I assure you...
post some pics here to of the open LDA case.
Dark Projects...
Reply #12August 06, 2009, 12:43:41 am
carrizog60
  • 978
« Reply #12 on: August 06, 2009, 12:43:41 am »
yesterday took a look at it...
nothing,zero,nada...
empty as a shell...
does anyone have a pic were it shows what i need to remove in order to put the lda top working?
Portugal
Reply #13August 06, 2009, 09:38:11 pm
Syncroincity
  • 727
« Reply #13 on: August 06, 2009, 09:38:11 pm »
I just ran into this myself... got a call from Giles: "Your 'LDA' is empty. The pump needs a real LDA and a different camplate to be of any use as a performance pump."  That'll add to the bill, you can bet... oh well.
AAZ pumps are not kosher. :(
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #14August 07, 2009, 12:15:08 am
carrizog60
  • 978
« Reply #14 on: August 07, 2009, 12:15:08 am »
diferent camplate?
Portugal
