Author Topic: New Pre Chambers Available?  (Read 33539 times)
Reply #30January 29, 2010, 06:51:54 pm
Re: New Pre Chambers Available?
« Reply #30 on: January 29, 2010, 06:51:54 pm »
thats a pic of a prechamber, but theres no price or anything.
Reply #31January 29, 2010, 08:20:03 pm
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
« Reply #31 on: January 29, 2010, 08:20:03 pm »
I have Skype, I'll try calling.
Reply #32January 31, 2010, 12:41:54 am
NintendoKD
  • 931
    • myspace page
« Reply #32 on: January 31, 2010, 12:41:54 am »
my aaz parts thread has the answer, any word on the aftermarket cups yet?
Reply #33January 31, 2010, 08:00:28 am
« Reply #33 on: January 31, 2010, 08:00:28 am »
isnt aftermarket anything that is not OEM? thats always what i thought. so technically these ARE after market.
Reply #34January 31, 2010, 08:51:39 pm
NintendoKD
  • 931
    • myspace page
« Reply #34 on: January 31, 2010, 08:51:39 pm »
any word on this? ;)
Reply #35February 01, 2010, 04:54:15 pm
dbk
  • 8
« Reply #35 on: February 01, 2010, 04:54:15 pm »
what happened to your pre cups? they are such hard material, I did'nt think anything could go wrong with them. I have heard they can get loose in the head but that's a head problem
Reply #36February 01, 2010, 09:11:07 pm
rodpaslow
  • 670
« Reply #36 on: February 01, 2010, 09:11:07 pm »
I've got one in a TD 1.6 head that is cracked 75% the way around it. (through the center of the opening up around the wall of it)
I bought a cheap replacement head and they are steel as they are magnetic.  I might as well throw this head away as it won't last.
1 need to replace this 1 prechamber/swirl chamber and it seems almost impossible to find them.  Do 1.6 NA fit TD?  I thought I read on here
that they don't?
They are a very hard material, I think as said before a Nickel based alloy.
Reply #37February 01, 2010, 10:55:29 pm
NintendoKD
  • 931
    • myspace page
« Reply #37 on: February 01, 2010, 10:55:29 pm »
all four precups on my aaz head are cracked, probably a magnetic metal.  won't know for sure until I get back to the car, It's in Victorville, after a crash that totaled my car. :o  I now have a totaled car to worry about. :'(
Reply #38February 02, 2010, 07:38:38 am
« Reply #38 on: February 02, 2010, 07:38:38 am »
inconel is VERY magnetic. but what dies it matter? the block is pretty magnetic too.
Reply #39February 02, 2010, 07:57:16 am
rodpaslow
  • 670
« Reply #39 on: February 02, 2010, 07:57:16 am »
I guess the magnetic thing - the only point I was trying to make is that these are not a low alloy steel of some type.  They could be a copper/nickel mix of some type that is a hard material as it chewd up a carbide I was using to see how deep the cracks were.  I guess all I was saying is they are not steel.  It has a marking on the side of it that says CU68 (one other letter I can read CU68X).
Reply #40February 02, 2010, 07:58:44 am
« Reply #40 on: February 02, 2010, 07:58:44 am »
inconel is some sort of nickel-copper steel alloy... SUPER HARD
Reply #41February 02, 2010, 08:04:19 am
rodpaslow
  • 670
« Reply #41 on: February 02, 2010, 08:04:19 am »
The marking on the side of it is (cleaned it off better) CU H1, under that is 068F. Part # perhaps?
Reply #42February 03, 2010, 12:08:48 am
NintendoKD
  • 931
    • myspace page
« Reply #42 on: February 03, 2010, 12:08:48 am »
found these guys in the archives, seems some folks have forgotten bout em'
http://www.aluminumheads.com/
For more info call: 503-230-0852,
Or toll free: 1-800-978-HEAD (4323)
Talk to Wayne or Chuck
Reply #43February 03, 2010, 09:25:28 am
sdwarf36
  • 159
« Reply #43 on: February 03, 2010, 09:25:28 am »
 No it isn't. Tried mine this morning. Discussions I had with my boss at work about grinding them on our (mag base) surface grinder. Said years back when these were more common he had to make up a steel fixture with set screws to to hold them so they could be ground.
91 Jetta on WVO na / td swap in progress.
 "VW happiness is having 4 working door handles."
Reply #44February 03, 2010, 09:44:45 am
« Reply #44 on: February 03, 2010, 09:44:45 am »
wtf...
my prechambers out of my 1.5 were magnetic.
cause i got one too close to my sub woofer, and it stuck to it.
and another thing, i just took a precup, and stuck a magnet to it. and it stuck GOOD.
besides, ferrous metal is magnetic, and precups rust, so that tells me there is some sort of iron in there.
