Author Topic: New Performance Nozzles?  (Read 5410 times)
July 23, 2009, 10:22:57 am
Duzty
  • 34
« on: July 23, 2009, 10:22:57 am »
I need some new nozzles, and i need them to get around 300hp+  ;D
Right now i'm running at std. AAZ nozzles.
VW Golf mk2 1.9TD - FMIC, GT2860RS - 11mm Pump.
1/4 Mile - 13,24 :twisted:
Reply #1July 23, 2009, 11:40:12 am
GEE-BEE
  • 1604
Re: New Performance Nozzles?
« Reply #1 on: July 23, 2009, 11:40:12 am »
Kermatdi has them...
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2July 24, 2009, 08:04:50 am
Duzty
  • 34
« Reply #2 on: July 24, 2009, 08:04:50 am »
Can't find any IDI nozzles at their site.
Reply #3July 24, 2009, 08:10:22 am
« Reply #3 on: July 24, 2009, 08:10:22 am »
And that's because the stock nozzles flow more than enough fuel for just about any application the engine can handle.  ;)
IDI performance tuning is mostly about making the engine breath easier (bigger exhaust), adding more fuel (modifications to the IP pump) and adding more air (turning up the boost), all under the watchful supervision of EGT and boost gauges.
If you read thru the FAQ you'll find various threads on performance turning, and there are professional builders out there who build super-modified pumps.
Reply #4July 24, 2009, 08:20:18 am
rabbid79
  • 684
« Reply #4 on: July 24, 2009, 08:20:18 am »
That website isn't organized very well.  Here they are:http://www.kermatdi.com/servlet/-strse--dsh-Maintenance-Items-cln-A1-and-A2-cln-Fuel-System-cln-Nozzles/Categories
'15 WRX
Reply #5July 24, 2009, 01:06:17 pm
Duzty
  • 34
« Reply #5 on: July 24, 2009, 01:06:17 pm »
Those are standard nozzles.  ???
I drive with 45psi on a GT30 turbo.
W/M injection. 11mm special made pump. 3" exhaust. GIANT FMiC with 3" pipes.
But the head is still std! So that is the next project, and also the nozzles.
Reply #6July 24, 2009, 01:10:21 pm
« Reply #6 on: July 24, 2009, 01:10:21 pm »
you will be fine with stock nozzles.
dave cross made 193 hp on stock nozzles and a 9mm pump.
the nozzles are way big enough to flow lots of power. just make your pump give them more fuel.
Reply #7July 25, 2009, 03:36:14 am
Duzty
  • 34
« Reply #7 on: July 25, 2009, 03:36:14 am »
OK. Right now i'm making aprox 300hp.
Reply #8July 25, 2009, 04:30:51 am
MJF
  • 581
« Reply #8 on: July 25, 2009, 04:30:51 am »
Donīt worry about injectors, focus on cylinder head and pump.
« Last Edit: July 25, 2009, 04:33:30 am by MJF »
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #9July 25, 2009, 05:52:04 am
rabbid79
  • 684
« Reply #9 on: July 25, 2009, 05:52:04 am »
Can you give us your recipe for 300HP? :o  What kind of torque are you making?  Where are you located?
« Last Edit: July 25, 2009, 12:00:06 pm by rabbid79 »
'15 WRX
Reply #10July 25, 2009, 10:38:26 am
Kantdrivefast
  • 196
« Reply #10 on: July 25, 2009, 10:38:26 am »
Can you give us your recipe for 300HP? :o  What kind of torque are you making?  Were are you located?
Or a dyno sheet....
Everyone on the internets making 300hp ::)
Reply #11July 27, 2009, 02:17:39 am
« Reply #11 on: July 27, 2009, 02:17:39 am »
lol, my rabbit has 324 wheel horsepower and 700 ft lbs of torque too :P
Reply #12July 27, 2009, 03:38:17 am
MJF
  • 581
« Reply #12 on: July 27, 2009, 03:38:17 am »
If you guys would use some search you would find this in 10 seconds ::)
http://www.vwdiesel.net/forum/index.php?topic=16008.0
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #13July 27, 2009, 06:36:20 pm
Rabbit TD
  • 840
« Reply #13 on: July 27, 2009, 06:36:20 pm »
Well that gives me some hope and what to shoot for, I'm at around 65 right now I guess, I don't have the T/D pump back on yet and that might be stretching it some besides, probably 62 ;D
Reply #14July 27, 2009, 11:44:37 pm
« Reply #14 on: July 27, 2009, 11:44:37 pm »
my rabbit rips. usually i can get a good posi burn out into like 3rd gear when its dry out. i dont even like driving my car aggressively when its wet out, breaks the tires loose too easy when its pouring. i figure it has like around 130 hp, considering all the things ive done to it. it would chew my gas jetta up.
