VWDiesel Blog
Facebook Group
VWD on Twitter
General Information
Troubleshooting
Relay Feed?
Topic: Relay Feed? (Read 3471 times)
July 03, 2009, 01:09:03 pm
1340
Relay Feed?
July 03, 2009, 01:09:03 pm »
Can anyone suggest a signal wire to run a relay? Passat, 1993, diesel.
Key on-on, key off-off (with key in ignition switch).
Colours?
Thanks.
July 17, 2009, 09:07:10 am
somolovitch3
Re: Relay Feed?
July 17, 2009, 09:07:10 am »
What are you trying to switch? Are you trying to access an existing wire, or add anew one?
If your radio turns on/off with the key, that fuse could be tapped for the feed.
Or you could tie into the output side of the X relay.
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
General Information
Troubleshooting
Relay Feed?
