Author Topic: AAZ engine hard to start. Timing?  (Read 3536 times)
June 17, 2009, 02:17:17 am
haybayian
  • 155
« on: June 17, 2009, 02:17:17 am »
Hello Group. Everything seems to be OK. I redid the IP timing, fuel pump working, etc and yet the thing takes a very long agonizing cranking before firing.  Should I fiddle with the IP 3 bolt mount? If so should I pull the pump away from the block or vice versa? Sorry to be so crudely ignorant.
Haybayian
Keep it simple if you can.
Reply #1June 17, 2009, 02:21:31 am
Zulfiqar
  • 254
Re: AAZ engine hard to start. Timing?
« Reply #1 on: June 17, 2009, 02:21:31 am »
seems as if your pump is draining off fuel, you have an airleak somewhere in the return system, the little rubber overflow pipes are a once only install and seal just once, or the return fitting is letting in air to drain off fuel from the pump
Diesel IS the future
Reply #2June 17, 2009, 01:15:31 pm
haybayian
  • 155
« Reply #2 on: June 17, 2009, 01:15:31 pm »
Thanks,
Could you explain. How would a faulty return fuel line (letting air in) could interfere with the starting of this engine?
Haybayian.
Reply #3June 19, 2009, 02:51:31 am
Golf/Jetta
  • 102
« Reply #3 on: June 19, 2009, 02:51:31 am »
is it when the engine is cold? if so the glowplugs, compression, air getting in the IP
if its happening when hot, air getting in the IP.
Thanks,
Haybayian.
is it leaking anywhere?
if air is getting in the pump then the one way check valve could be faulty
the IN fuel line is under vacuum from the pump
a working IP, pumps about 12 psi inside, if not more (30 psi)
but a faulty return line should leak it.
an IN line to the pump would let in air if there a leak..
lets say the bonjo bolt, copper O-ring "IN port", on the pump is leaking
then air has a way of getting in the pump, but should only effect after it cranked over. unless alot of air got in. oneway check vavle (FUEL GOING BACK TO THE TANK)
to prove this, you could rig something up to throw fuel at it and see if it leaks somewhere. air pressure test (no more then 12 psi) and see if it holds it.
another one could be a seperate fuel source.
try blowing back to the tank on the IN fuel line, if it goes back then check valve.
if all check out OK then i would have to say compression or glowplug system when cold
how is your compression?
glowplugs work?
is your anitfreeze staying put?
« Last Edit: June 19, 2009, 02:53:24 am by Golf/Jetta »
'97 Jetta - 4Dr - 1.9 TiDi (Forth Car)
'94 Jetta - 4Dr - 2.0L Swaped in an AZZ - Almost done 2011 b4 Winter (Third Car)
Blue '87 Golf - 2Dr - Tags (First Car)
Red '92 Jetta (W) - 4Dr - Sold to Friend For $200 (Second Car)
Thanx For Answering My Posted Question's/Comments...
Reply #4June 19, 2009, 05:47:47 am
haybayian
  • 155
« Reply #4 on: June 19, 2009, 05:47:47 am »
Thanks again,
My problem seems to be cold start indeed. I am therefore going to make my glow plugs functional.
Haybayian
