Author Topic: oil leak from head gasket  (Read 1994 times)
June 15, 2009, 11:29:50 am
92EcoDiesel Jetta
« on: June 15, 2009, 11:29:50 am »
I've replaced the valve cover gasket with the rubber one with shoulderless studs, it is mostly dry on the front side but still seeping a little on the turbo side. The IP leak has been fixed so the only leak I see now is a little oil seeping of the headgasket (where the notched holes are) around cyl 2&3. Is that normal or something that should be attended to? I am still trying to find the cause of why the engine is missing and idles rough after it is fully warmed up. Maybe this leaky head gasket has something to do with it?
