Author Topic: Removing the Oil Cooler  (Read 3997 times)
June 09, 2009, 06:42:35 pm
catlin_cava
  • 1954
« on: June 09, 2009, 06:42:35 pm »
How the Hell do I remove the oil cooler???
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #1June 09, 2009, 06:49:21 pm
Re: Removing the Oil Cooler
« Reply #1 on: June 09, 2009, 06:49:21 pm »
27mm injector socket works perfectly on the nut.... it's on the tube the oil filter screws into.
Reply #2June 09, 2009, 07:28:02 pm
catlin_cava
  • 1954
« Reply #2 on: June 09, 2009, 07:28:02 pm »
Is That to remove it from The block?
Catlin
Reply #3June 09, 2009, 07:38:11 pm
« Reply #3 on: June 09, 2009, 07:38:11 pm »
Nope, that removes it from the oil filter flange.  The oil filter flange bolts to the block with three bolts.
Reply #4June 10, 2009, 05:45:12 am
catlin_cava
  • 1954
« Reply #4 on: June 10, 2009, 05:45:12 am »
I need a really big hammer   ;D ;D
Catlin
Reply #5June 10, 2009, 09:37:33 am
arb
« Reply #5 on: June 10, 2009, 09:37:33 am »
Once you remove the nut (on the same threaded pipe the filter screws onto) it should be easy to remove by hand from the aluminum flange bolted to the block. Maybe the rubber gasket is stuck between the 2 ?
Reply #6June 10, 2009, 10:04:22 am
catlin_cava
  • 1954
« Reply #6 on: June 10, 2009, 10:04:22 am »
its not going to be hard to take it apart. its one of the 3 bolts to the block is stripped.
Catlin
Reply #7June 10, 2009, 11:16:27 am
arb
« Reply #7 on: June 10, 2009, 11:16:27 am »
Man, that's not fun. Drill, heat, easy-out (Quality one, not from China)
Reply #8June 10, 2009, 11:27:51 am
catlin_cava
  • 1954
« Reply #8 on: June 10, 2009, 11:27:51 am »
I may just junk the block anyways,
Catlin
Reply #9June 11, 2009, 05:46:08 pm
catlin_cava
  • 1954
« Reply #9 on: June 11, 2009, 05:46:08 pm »
Well I got the oil cooler off....some easy outs(really good ones) then bolts come right off.
Catlin
