Author Topic: Intercooler on a GTD. Any good?  (Read 3013 times)
June 09, 2009, 04:21:45 pm
airhead
« on: June 09, 2009, 04:21:45 pm »
I have a golf 2 GTD. I was looking at my intercooler trying to figure out how the airflow works on it. From what I can tell, it seems to absorb a lot of heat from the radiator and doesnt get cooled all that well. Is it worth a toss or what? Would it be worth putting a fan on it? Im just curious really. Also, is it a big deal if quite a few of the fins are bent down?
Ive never had a car with an intercooler before, so Im just learning here, as Im sure you can appreciate. Any info you can provide would be very much appreciated. Thanks.
Reply #1June 09, 2009, 07:17:58 pm
bevboyy
  • 200
Re: Intercooler on a GTD. Any good?
« Reply #1 on: June 09, 2009, 07:17:58 pm »
It would be better to relocate the IC to somewhere where it can receive better, unimpeded airflow.(ie: infront of the rad) The only downside to this is fabbing up the piping for it.
1987 Jetta Mk2 - daily driver, MZ 1.8 goodness. TJ auto trans..
Gone but not forgotten:
1985 Mercedes 300d Turbo
1987 Olds Delta 88 Royal Brougham
1992 Mercedes 190e 2.3
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1979 Mercedes 300D (non turbo)
1977 BMW
Reply #2June 10, 2009, 03:17:11 am
airhead
« Reply #2 on: June 10, 2009, 03:17:11 am »
Would there be a noticable performance and/or economy gain by doing this?
Reply #3June 10, 2009, 03:21:08 am
Zulfiqar
  • 254
« Reply #3 on: June 10, 2009, 03:21:08 am »
the GTD cooler works on the pressure differential principle, the engine bay is exhausted under the car when its moving, and in turn air needs to replace the exhausted air - thats how air gets pulled into the cooler - and then theres also some pressure coming from the grille
Diesel IS the future
Reply #4June 10, 2009, 10:38:19 am
airhead
« Reply #4 on: June 10, 2009, 10:38:19 am »
Would a fan help or would that just impede airflow too much when its not on?
Reply #5June 10, 2009, 10:42:41 am
« Reply #5 on: June 10, 2009, 10:42:41 am »
a fan would be a great idea.  make it thermostatically controlled though.  rainbow electronics makes a real nice one that will work from 0C to 100C.  a real good way to eliminate heat soak  ;)
