Author Topic: m-tdi w/ 1.6 pump  (Read 1800 times)
June 08, 2009, 06:24:23 am
ObscuredByClouds
  • 98
m-tdi w/ 1.6 pump
« on: June 08, 2009, 06:24:23 am »
What would an m tdi be like with a 1.6 pump?
« Last Edit: June 08, 2009, 09:27:38 am by NoSurrenderAG »
Reply #1June 08, 2009, 02:07:50 pm
  • 5103
Re: m-tdi w/ 1.6 pump
« Reply #1 on: June 08, 2009, 02:07:50 pm »
slow.  it would run but not properly.  you can use a 1.6 pump as a base, but then you'll want to put in the tdi cam plate, atleast a 10mm head, find some way to make the timing advance faster.  theres no bolt on tdi m pump that will work properly.
