Author Topic: NA13x injectors  (Read 1889 times)
June 05, 2009, 08:21:09 pm
RustyCaddy
  • 395
NA13x injectors
« on: June 05, 2009, 08:21:09 pm »
Hoping someone could shed some light on this.
Found 4 NA13X injectors for a 1.6NA...they were remanufactured by Bosch and have  sleeve that wraps around the injectors where the VW part numbers are...the sleeve says NA13X so the right application for a 1981 engine.
I took the sleeves off cause they probably wouldn't survive on the engine forever and a found different VW part numbers on them: ending with: 201 C, 130 bar (as expected), a 201 B, 155 bar (turbo), and a 201 P, 155 bar (turbo).
I guess that since the bodies are the same between the different types of injectors that if they all have the nozzles specified for a 201 C then that is why they are all boxed and listed as NA13X.  Does that make any sense?
Any thoughts/comments out there are really appreciated?
Thanks
Reply #1June 06, 2009, 10:17:36 am
RustyCaddy
  • 395
Re: NA13x injectors
« Reply #1 on: June 06, 2009, 10:17:36 am »
libbybapa...Thanks for the help.
