Author Topic: Gasoline oil filter on a diesel...  (Read 5873 times)
Reply #15May 30, 2009, 03:27:03 pm
Jettagli16v
  • 344
Re: Gasoline oil filter on a diesel...
« Reply #15 on: May 30, 2009, 03:27:03 pm »
I have always been particular about oil filters since I started changing it myself,
always Mahle or Mann filters.
I buy them by the case and am set for a long while. (its the way I can afford it: $5-6 ea)
I have never had a single oil filter related issue (in 13 years in Mk2's!)
I did not look at this one before I put it on,
but I wonder if they have a spring loaded filter bypass to sustain flow like the mahle for the 16v?
-Brad
Reply #16May 30, 2009, 04:16:53 pm
dieselherb1
  • 354
« Reply #16 on: May 30, 2009, 04:16:53 pm »
Just wondering how many miles do you guys have on yours engines using Mann or others expensive filters? You talk with great experience.
Reply #17May 30, 2009, 06:02:36 pm
macka
  • 957
« Reply #17 on: May 30, 2009, 06:02:36 pm »
on my first golf I had almost half a million k before I packed it in, I changed at the recomended service intervals give or take 200 K. I just believe in regular PM, and for the record I've only used Fram in chevies and fords.
Quote from: Vincent Walden
Reply #18May 31, 2009, 03:21:45 pm
Jettagli16v
  • 344
« Reply #18 on: May 31, 2009, 03:21:45 pm »
Hmm... Hard to exactly calculate the miles I have put on Mk2 or Mk3 chassis,
but, (in chronological order)
88 Golf, 1.5 yrs = 20k mi
91 GLi 16v, 3.5 Yrs = 80k (?)
98 GTi 2.0, 8 yrs = 140k miles,
85 Jetta TD, 1 year, 20k miles.
(I have never not driven a watercooler full time! from 1996 to now)
I drive a lot. (for a city dweller anyway)
I have averaged 20k miles / yr.
And always been in a Mk2 chassis (I still consider 4 cylinder Mk3's Mk2's)
with 4 cylinders, 5 speeds, and manual windows...
(and German oil filters!)
Only way to fly!
Now, I have had an aircooled (78 camper Bus), for 9 years so far,
but never daily driven. She's a 77,000 mile garage queen.
-Brad
Reply #19June 01, 2009, 08:38:39 pm
DieselSteed
  • 107
« Reply #19 on: June 01, 2009, 08:38:39 pm »
I had the same trouble (filter clearance) when I installed the TD into my caddy. I found a MANN filter from an Audi 100TD (Mann W1130/1). The filter is shorter so it did not interfere with the rad support. However, the filter is fatter, and would not fit until I removed the welded nut from the heater tube (the one that goes from the water pump to the heater core, the nut for the starter motor bolt).
When my lady really wants to get me in the mood, she rubs a little diesel behind her ears.
