Author Topic: clearance between turbo and firewall...1/2" ok?  (Read 2542 times)
May 26, 2009, 03:07:05 pm
flapjack
  • 283
« on: May 26, 2009, 03:07:05 pm »
I've got new motor mounts and about 1/2" between the turbo and the firewall.
What do you guys think? Will the turbo be beating against the wall?
signature
Reply #1May 26, 2009, 05:45:58 pm
Re: clearance between turbo and firewall...1/2" ok?
« Reply #1 on: May 26, 2009, 05:45:58 pm »
i'd say its possible  what car is this in?
Reply #2May 26, 2009, 08:15:51 pm
flapjack
  • 283
« Reply #2 on: May 26, 2009, 08:15:51 pm »
93 golf with a 1.6td, not the stock manifold.
signature
Reply #3May 26, 2009, 08:23:42 pm
cyrus #1
  • 360
« Reply #3 on: May 26, 2009, 08:23:42 pm »
Which way will the engine rock when you get on the loud pedal?  Either way it sounds pretty close.  Think of the heat that will be transferred.
That looks like a rather large turbo.  Please do tell.  ;)
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #4May 26, 2009, 09:45:22 pm
Powered by Spearco
  • 1203
« Reply #4 on: May 26, 2009, 09:45:22 pm »
The front of the engine lifts and the back lowers down. Run stiffer front motor mount from a G60, and make sure your rear engine and trans mounts are good.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #5May 27, 2009, 04:26:19 am
flapjack
  • 283
« Reply #5 on: May 27, 2009, 04:26:19 am »
ok, thanks I'll give it a try.
cyrus: turbo is a T3 from an old saab, should be the same as the ones some vw td;s came with
signature
Reply #6May 27, 2009, 09:45:16 am
« Reply #6 on: May 27, 2009, 09:45:16 am »
your turbo most likely has a bigger pitch and A/R on the turbine housing. gasser turbos usually have bigger specs, because they use more rpms to spool the turbo. the low pressure turbo on my car is off of a 2.5 l chrystler lebaron or something. its physically the same turbo as a VW t3, it has a bigger exhaust housing on it tho, and it has an A/R of 48, versus the stock 36 A/R of a VW diesel T3.
