Author Topic: cracked head  (Read 4808 times)
May 25, 2009, 09:27:11 pm
westcoaster
cracked head
« on: May 25, 2009, 09:27:11 pm »
My headgasket popped and was dribbling coolant out the front of the engine. I pulled it all apart with the intent of replacing the headgasket. It was suggested I take the head in to get checked out. There are only two sylinders with cracks between the valves and according to the machine shop one of them are leaking between intake and exhaust. (small crack less than a MM )
From reading this isn't good but not necessarly bad either. The head will still run and run well but just have a short life expectancy (correct?)
If I understand correctly the crack will eventually progress into the water jacket and pressurize the cooling system.
I have swapped this motor into a suzuki samurai and want to ensure I have any cooling bugs worked out before I spring for a new head. I have a couple areas that I may be having problems. Air trapped. Bad hose routing and a poor radiator. May have a bad thermostat as well....
The bottom end had 383,000km before the odo stopped working on the donor car but it seems pretty tight (wasn't much blowby and the pistons are reasonably tight in the holes but there is a bit of a ridge)
Considering the crack, should I still get the head shaved (flattened) or bolt it back together as is with a new gasket?
'87 suzuki samurai with a 1.9 AAZ TD transplant
Reply #1May 26, 2009, 02:30:42 am
Mark(The Miser)UK
  • 1557
Re: cracked head
« Reply #1 on: May 26, 2009, 02:30:42 am »
Peen it shut with a punch IMO...
Mark-The-Miser-UK
Reply #2May 26, 2009, 11:21:38 am
88jetta350
Re: cracked head
« Reply #2 on: May 26, 2009, 11:21:38 am »
I thought you weren't supposed to shave a diesel head unless absolutely needed?  ???
BTW, +1 on peening the crack shut.
Reply #3May 26, 2009, 05:31:08 pm
westcoaster
Re: cracked head
« Reply #3 on: May 26, 2009, 05:31:08 pm »
I'm getting conflicting opinions on this....
As for the peening...
Take a punch and on either side deform the aluminum just enough to close the crack a little?
Couple good whallops? many tiny taps?
Reply #4May 26, 2009, 11:42:35 pm
maxfax
  • 2126
Re: cracked head
« Reply #4 on: May 26, 2009, 11:42:35 pm »
I always prefrred tiny taps..  But I tend to be sort of agressive with a hammer....
AS far as shaving the heads I've only done do when they are warped out of spec..   And any of the heads that I have had that were out of spec were warped bad enough they needed straightened (basically bent back) before they could be shaved..   Some prefer to just shave them and have the cam journels line bored.. Both accomplish the same thing..
If you just shave a head that has warped signifigantly there is a very good chance the the cam journels are not in a line which will put stress on teh camshaft itself causing either the journel in the head or on the cam to wear more.. I've also heard stories of cams breaking because of this, although not on a VW engine yet..
Did the gasket look like it just deteriorated from age and was the engine run hot? If it wasn;t severely overheated chances are you can just peen the cracks and slap a gasket in..    Which head bolts does you engine have BTW, 11mm or 12mm???
Reply #5May 27, 2009, 01:03:24 am
Baxter
Re: cracked head
« Reply #5 on: May 27, 2009, 01:03:24 am »
No probs with skimming, we do it all the time.
That's the joy of infinatly adjustable cam timing.
Reply #6May 27, 2009, 10:06:50 am
Re: cracked head
« Reply #6 on: May 27, 2009, 10:06:50 am »
the only reason they say not to plane a diesel head, is because most of the time, the retards at the shop leave the Inconel pre cups in the head. Inconel vs. Aluminum... what metal is harder? hmm, maybe aluminum since you can pretty much look at it wrong and warp it? but yea, Inconel doesnt plane down at the same rate as the aluminum. but if you pop the pre cups out and have the head shaved, then get the pre chambers fly cut so that the pre cup will sit flush with the deck of the head again, you will be good to go.
Reply #7May 27, 2009, 11:03:03 pm
westcoaster
Re: cracked head
« Reply #7 on: May 27, 2009, 11:03:03 pm »
Not sure if they date code the gaskets. If they do it looked like this one was from '98.
I can't say if it was overheated before I got it. It was low on coolant when I bought the car (none in the expansion tank)
I only drove the thing 60Km before I ripped the motor out. when I dropped the coolant it left a nice black ring around the bucket....
It did get pretty warm once when I had it out in the samurai. The samurai temp guage was still not pegged though....
I think I have the 12mm bolts at least that is the tripple square size used to take them out....
Reply #8May 28, 2009, 09:11:52 am
Re: cracked head
« Reply #8 on: May 28, 2009, 09:11:52 am »
if you used a triple square, they are 12's. all the 11mm bolts just have normal 10mm allen heads.
Reply #9May 28, 2009, 10:31:45 am
maxfax
  • 2126
Re: cracked head
« Reply #9 on: May 28, 2009, 10:31:45 am »
Whew!  Yes 12mm.. No need for the head stud speech today..
Reply #10May 28, 2009, 11:00:40 am
Re: cracked head
« Reply #10 on: May 28, 2009, 11:00:40 am »
there is always the need for the head stud speech.
so, here goes...
GET SOME FRIGGEN HEAD STUDS!!!
Reply #11May 28, 2009, 11:01:44 am
arb
Re: cracked head
« Reply #11 on: May 28, 2009, 11:01:44 am »
I just blew my HG too. Did you check your head ? Bentley says 0.004" is the limit. I was close, so I took another approach. I 'sanded" most of the warp out of mine. Look at the photos, you'll see the pre-cups also came down a little. In the next few days I'll know if this resolved my problem. I DID over heat it, but have no visible cracks. I need to fix my new temp gauge too. Its a Sun Pac that the needle jumped the peg, so it bottoms out on the peg and I could not tell I was cooking the aluminum.
http://www.vwdiesel.net/forum/index.php?topic=15633.255
Reply #12May 28, 2009, 12:38:16 pm
maxfax
  • 2126
Re: cracked head
« Reply #12 on: May 28, 2009, 12:38:16 pm »
so, here goes...
I let it slide on 12mm N/A's although they are still well worth it..   IF he'd said 11mm bolts I would have jumped on the pulpit...
Reply #13May 29, 2009, 05:26:05 am
arb
Re: cracked head
« Reply #13 on: May 29, 2009, 05:26:05 am »
so, here goes...
I tried to get studs for my latest HG, but with the forum still down, I could not find a source. The local suppliers did not know what part numbers to look up. ( SE Michigan) The diesel guy remembers the Cogsworth studs back in the day, but said he didn't know what # to find.
Reply #14May 29, 2009, 07:04:10 am
westcoaster
Re: cracked head
« Reply #14 on: May 29, 2009, 07:04:10 am »
so, here goes...
The exact problem here as well. emailed the parts house, nope no studs here! had no idea where to get them in or around Vancouver BC.
