Author Topic: catalytic converter  (Read 1858 times)
May 25, 2009, 12:48:37 pm
juleshs
  • 49
catalytic converter
« on: May 25, 2009, 12:48:37 pm »
my exhaust is blowing near the cat i get rid of the cat and run my exhaust without one???
Reply #1May 25, 2009, 06:05:23 pm
diesel smoke
  • 209
Re: catalytic converter
« Reply #1 on: May 25, 2009, 06:05:23 pm »
Yes, but if you have to get emissions checked, you're screwed. ;)
'99.5 Bora TDI
'88 Fox Coupe
'71 Tin Top Westfalia Bus
'85 Mercedes 300SD
Reply #2May 26, 2009, 08:41:09 am
arb
« Reply #2 on: May 26, 2009, 08:41:09 am »
That is the question... do you have required emission tests?  If not, you'll get a little better mpg w/o the cat. If you have the tests, find out what the rules are for your car. In the US, the first "green diesel's" were IDI with a cat. The emission standards of the day (1986 ?) did not require the cat. And in Michigan when they did have testing in the Detroit area, if you failed a test on an older car, you could get the mechanic to sign-off saying it was too costly to repair, and you had your pass on the test anyway.
