Author Topic: Lifter Interchange-ability  (Read 2427 times)
May 21, 2009, 08:38:35 pm
ein bora
  • 377
« on: May 21, 2009, 08:38:35 pm »
I have a sporadic lifter noise coming out of my 1.9 IDI. This can happen at any time, high speeds and or at idle and can last for a few seconds to much longer, but not minutes upon minutes. I've tries some of the readily available chemical fixes to no avail. My assumption is that it's a collapsed lifter. As I have a bunch of 1.6 lifters - does anybody know if the 1.6 lifters will interchange with the 1.9's?? Thanks.
If you can't take advice - then you can't be helped!
Reply #1May 21, 2009, 11:06:21 pm
  • 3468
    • McScrubbins Body Wash
Re: Lifter Interchange-ability
« Reply #1 on: May 21, 2009, 11:06:21 pm »
Haha!!
I had this question in the reverse order to save money on my AAZ head build. I used my 1.6 hydro lifters and cam on my aaz head. Measure the width and you should see! they are the same :D . Use the search and look for ... "how to tell if a lifter is bad" or something :P
Reply #2May 22, 2009, 03:46:52 am
Golf/Jetta
  • 102
« Reply #2 on: May 22, 2009, 03:46:52 am »
they fit
if you look at the bottom the 1.6l lifter (year 92), there more down. 1.9L lifter are more up/in...(year 96 97)
93 - 95  8mm valve thinkness // 96 - 97  7mm valve thinkness
you could try, its just time consuming
take note of the oil ring gap around the lifters
a 2.sl0w lifter looks the same as the 1.6's
'97 Jetta - 4Dr - 1.9 TiDi (Forth Car)
'94 Jetta - 4Dr - 2.0L Swaped in an AZZ - Almost done 2011 b4 Winter (Third Car)
Blue '87 Golf - 2Dr - Tags (First Car)
Red '92 Jetta (W) - 4Dr - Sold to Friend For $200 (Second Car)
Thanx For Answering My Posted Question's/Comments...
