Author Topic: 1.9 AAZ Weight  (Read 8975 times)
May 07, 2009, 04:26:08 pm
catlin_cava
  • 1954
1.9 AAZ Weight
« on: May 07, 2009, 04:26:08 pm »
Does a 1.9 AAZ weight more then 750lbs??? I'm looking at getting an stand for it and the 750 one at princess auto is only 49.99? will it work
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #1May 07, 2009, 04:31:23 pm
1.9 AAZ Weight
« Reply #1 on: May 07, 2009, 04:31:23 pm »
It's well under 750. I can lift the whole motor myself (not high, and not for long mind you)
Make sure that the motor stand has a nice rotating stand, and a good place to put a big bucket under it.
Reply #2May 07, 2009, 04:43:57 pm
catlin_cava
  • 1954
1.9 AAZ Weight
« Reply #2 on: May 07, 2009, 04:43:57 pm »
perfect...Princess Auto is the best
Catlin
Reply #3May 07, 2009, 04:46:24 pm
1.9 AAZ Weight
« Reply #3 on: May 07, 2009, 04:46:24 pm »
Quote from: "catlin_cava"
amen.
Reply #4May 07, 2009, 05:08:27 pm
catlin_cava
  • 1954
1.9 AAZ Weight
« Reply #4 on: May 07, 2009, 05:08:27 pm »
7 days till i get to go :D
Catlin
Reply #5May 07, 2009, 05:38:59 pm
bigblockchev
  • 271
engine stand
« Reply #5 on: May 07, 2009, 05:38:59 pm »
I actually have one of the PA 750lb engine stand and I don't like it much. The one with only one wheel at the front is way too tippy. I have a VW engine block on it right now and it tries to tip when you roll the engine over. They make a 1000 lb unit with two front wheels which is much better and not much more expensive. If you have to spend money on tools make sure they are nice to work with not a pain. Cheers Dan
it's always something simple
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan  MDJF 15Kw genset
Reply #6May 07, 2009, 06:07:17 pm
1.9 AAZ Weight
« Reply #6 on: May 07, 2009, 06:07:17 pm »
i second that. the ones with one caster on the front are a waste of time.. i dunno how many times ive had to catch a falling engine.. and most of the time i end up messing up my back. i cut the single caster off mine and welded a 24" chunk of steel square stock and put wheels on each end.
Reply #7May 07, 2009, 06:17:28 pm
catlin_cava
  • 1954
1.9 AAZ Weight
« Reply #7 on: May 07, 2009, 06:17:28 pm »
I think I'll get the 750lb one, main reason its cheap...and like you did kevin and modify it, nothing some square tubing can't fix
Catlin
Reply #8May 07, 2009, 07:25:10 pm
1.9 AAZ Weight
« Reply #8 on: May 07, 2009, 07:25:10 pm »
one cut, a little grinder work, a couple holes drilled, and one weld.
VOILA!
instant beefy engine stand.
Reply #9May 07, 2009, 08:13:53 pm
catlin_cava
  • 1954
1.9 AAZ Weight
« Reply #9 on: May 07, 2009, 08:13:53 pm »
lol yup and its that easy
Catlin
Reply #10May 22, 2009, 08:34:34 pm
Syncroincity
  • 727
Re: 1.9 AAZ Weight
« Reply #10 on: May 22, 2009, 08:34:34 pm »
I just weighed an AAZ with a big fish scale and an engine crane...
400 lbs almost exactly.
Jerry
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #11May 23, 2009, 08:17:56 am
Re: 1.9 AAZ Weight
« Reply #11 on: May 23, 2009, 08:17:56 am »
Jerry
 :o I don't know what's crazier, that it weighed 400 lbs, or that you have a fish scale that goes up to 400 lbs!
What all was attached to the motor? Was oil and coolant in it?
Reply #12May 23, 2009, 10:31:05 am
Re: 1.9 AAZ Weight
« Reply #12 on: May 23, 2009, 10:31:05 am »
 :o 400 lbs? what all did it have on it? a transmission and everything? because i can pick up a runable 1.6 TD engine that has everything on it and oil in the pan. this engine didnt have a trans tho. but i packed that thing around a few times no problem. then one day i went to pack my 22R out of my basement, and i about *** a buick when i picked that thing up. its supposed to weigh 315 lbs. but i know that thing had at least 100 lbs on my diesel, and i knew it that day, i was hunched over for a couple days after that one. i just have a really hard time believing that an AAZ, or any VW diesel weighs 100 pounds less than a small block chevy.  ???
Reply #13May 23, 2009, 04:36:10 pm
Syncroincity
  • 727
Re: 1.9 AAZ Weight
« Reply #13 on: May 23, 2009, 04:36:10 pm »
All the accesories, IP, hoses, oil in the sump, motor mounts, flywheel, etc. etc... just like it came out of the car. "Wet weight"
No trans ;)
The scale actually only read up to 300 lbs, but the pointer kept going, & I marked where it pointed when the motor left the ground. The scale was 50lbs for every 3/4", and the motor lifted at 300 + 1.5", or 6" total deflection. Might be a margin of error going off scale, but it's close enough.
JC McCavitt
'98 Jetta Wolfie
Reply #14May 23, 2009, 04:43:03 pm
Re: 1.9 AAZ Weight
« Reply #14 on: May 23, 2009, 04:43:03 pm »
Tyler... you been pumping Iron or what!?!?! Holy Hell. lmao
Me (19) and a friend (51) lifted a complete "wet weight" n/a out of a golf and up on to a trailer by hand.... i thought he was going to have a stroke... I pulled a muscle something fierce. there is nooowayy it was under 500.. however just the engine is probably a lot lighter.. the whole shebang had to be AT LEAST 600lbs.
