Author Topic: prothe/emiata heads - experience?  (Read 10222 times)
April 07, 2009, 09:07:34 am
AndyL
« on: April 07, 2009, 09:07:34 am »
Ok, we've all seen the threads... Not trying to start a cheap chinese knockoffs vs the OEM debate - just trying to figure out whether to invest a bunch in fixing/welding up an OEM head or buying a cheap replacement...
Want some real world information - not speculation about quality etc...
It appears as though a few people here are using the prothe / emiata / etc heads... Real world experience - how are they holding up thus far? Any issues with tollerances / clearances / setup / assembly? Would you buy them again given what you know now?
Thanks in advance,
andy
Reply #1April 07, 2009, 09:18:51 am
« Reply #1 on: April 07, 2009, 09:18:51 am »
Smokey Eddy and Jimfoo are both running his heads.  i haven't heard of a failure from either one with regards to them.  if i were stuck for cash, and absolutely needed a head, i wouldn't hesitate to try one, but thats just me.
Reply #2April 07, 2009, 10:04:57 am
blackdogvan
  • 574
« Reply #2 on: April 07, 2009, 10:04:57 am »
I read somewhere here of someone having to line bore the cam shaft journals. After that it was ok.
1991 Vanagon 1.9 mTDI
Reply #3April 07, 2009, 04:01:11 pm
Baxter
« Reply #3 on: April 07, 2009, 04:01:11 pm »
What brand are they?
I use some AMC ones at work, the Spanish ones.
They get slated but I have really good results with them, the valves are a bit cheap looking but I tend to buy the bare heads and swap the German stuff into them.
Only issues I have had have been the 1.9's where the studs stick up for the rocker cover, the studs must be a tad too long and they won't let you tighten the head fully down, so they leak.
I put washers under the nuts and that cures it.
Reply #4April 07, 2009, 05:14:29 pm
« Reply #4 on: April 07, 2009, 05:14:29 pm »
Quote from: "Baxter"
the problem is that prothe won't disclose who makes them.  they are most likely of chinese origin, but then again, what isn't made in China anymore???  :lol:
and i'll agree that swapping over the German hardware is a good idea.  his prices are also generally 15-20% lower than most places for small hardware such as lifters, valves, seals, etc.  i wouldn't be surprised if the lifters are both of the same origin, as i heard from a head rebuilder that there is only 1 (or is it shut down now?) factory in NA that make lifters.
i think Smokey Eddy bought a complete head though? i could be wrong though, but i thought that the 1.6 hardware wouldn't work in a 1.9 head. and regardless, it seems as though he is having great success with his build.
Reply #5April 08, 2009, 07:44:12 am
« Reply #5 on: April 08, 2009, 07:44:12 am »
Smokey Eddy bought a bare head and assembled it his self.
Reply #6April 08, 2009, 08:05:33 am
« Reply #6 on: April 08, 2009, 08:05:33 am »
I cleaned up the TopLine head that is on the wife's car the other day, it looks to be a very good casting.  Ports are clean, flanges are nice and smooth, valves are good.  And no cracks between the valves!  :)  I've got no problems running it that I can see.  It also appears that the cam caps have been bored on it.
Reply #7April 08, 2009, 02:01:29 pm
AndyL
« Reply #7 on: April 08, 2009, 02:01:29 pm »
Not specifically asking about the topline heads - think there's enough info out there on those...
It's more these no-name ones prothe sells that I wonder about, did read about the one head that needed the cam align honed, google revealed someone who had to have several valve stem holes cleaned up (bored out to correct size). But then I wonder about that - as it seems no-one else has had that issue - perhaps he was using the wrong valves or (?).
I can see buying the no-name heads; but if they're going to need to visit the machine shop for fixing up - may as well buy the topline or repair an OEM head - price around here ends up about the same...
Reply #8April 08, 2009, 02:05:01 pm
truckinwagen
  • 1895
« Reply #8 on: April 08, 2009, 02:05:01 pm »
I have considered Prothe heads, mostly because local heads are impossible to find and shipping kills getting a used one from somewhere else, and prothe has really good shipping to AK.
but I just hit the motherload of OEM parts locally for cheap, so I will never know what his heads are like(fingers crossed)
83 Opel Kadett Diesel
Reply #9April 08, 2009, 02:34:03 pm
  • 3468
    • McScrubbins Body Wash
« Reply #9 on: April 08, 2009, 02:34:03 pm »
I bought the AAZ off him with valves and stem seals.
I reused (After sitting in solvent for weeks) my keepers, lifters, springs and what not off my 1.6. AND i reused my cam because they are the same.
It had some "bad" casting marks but since i was planning on polishing the ports anyways it wasn't a big deal.
the valves after some very very light lapping seated perfectly.
Reply #10June 03, 2009, 12:23:58 am
Syncroincity
  • 727
Re: prothe/emiata heads - experience?
« Reply #10 on: June 03, 2009, 12:23:58 am »
PROTHE, as we knew it, is no more, apparently. The new E-bay store is mickey444; all the same stuff, except looks like he dropped the european listings.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #11June 05, 2009, 09:16:34 pm
RustyCaddy
  • 395
« Reply #11 on: June 05, 2009, 09:16:34 pm »
Goggled the company that Prothe listed for his pistons...made in China I think and they seem to also make/sell cylinder heads and a bunch of other 1.6 liter stuff if I remember right.
Reply #12June 06, 2009, 01:34:55 am
  • 3468
« Reply #12 on: June 06, 2009, 01:34:55 am »
im also running his 9$/set piston rings. no complaints on my end EXCEPT that they break very easily during installation but i think all piston rings are fragile and for 9$/set who really cares.
I get 40+ mpg after 10,000km.
Reply #13June 06, 2009, 09:45:36 am
jimbote
  • 168
« Reply #13 on: June 06, 2009, 09:45:36 am »
He's a scumbag
« Last Edit: March 10, 2012, 03:29:47 am by jimbote »
Reply #14June 06, 2009, 10:40:33 am
ezekiel
  • 147
« Reply #14 on: June 06, 2009, 10:40:33 am »
I bought a camplate and rollers from him a while back.  I checked hardness of the camplate vs the stock one and dimensions of the cam and it was all within a couple thou, and it was a couple points higher in hardness, all well within any sort of tolerance.  The rollers I wasn't as pleased with since they're a 3 piece instead of the 2 piece I pulled out, which would allow for stacked tolerances, but Seattle Injector didn't pull them out when my pump was rebuilt, so I'm not worried.
I'd order from him again.
