Author Topic: timing  (Read 5751 times)
Reply #30March 29, 2009, 06:43:37 pm
jettabrendan
  • 198
    geschwindigkeitsueberschreitung
timing
« Reply #30 on: March 29, 2009, 06:43:37 pm »
nope 2 is thinner, 1 being thinnest 3 thickest.
1991 Jetta TD Dark Teal
1983 bmw e21 320is Hennarot
1997 Volvo 850 Black
Reply #31March 29, 2009, 06:50:25 pm
timing
« Reply #31 on: March 29, 2009, 06:50:25 pm »
for some asinine reason i thought 1 was thickest :P
Ok so you've boosted compression a bit.. aw hell i dunno.
it has to be timing! thats all thats left
Reply #32March 29, 2009, 08:58:51 pm
jettabrendan
  • 198
timing
« Reply #32 on: March 29, 2009, 08:58:51 pm »
i did everything except check piston prutrusion. seeing as people tell me that 95% come with 2 notchers i thought i had a pretty good chance that it was the right one. The head and gasket were replaced before and they might have just put in a 3 notch just in case. Would bad injectors cause it to do what its doing? not even a small hiccup?
Reply #33March 29, 2009, 09:33:45 pm
jettabrendan
  • 198
timing
« Reply #33 on: March 29, 2009, 09:33:45 pm »
yup, i lined everything up before i took it apart so it was all good when i put it back.  I did push the advance handle in too, but what happens if it is left out?
Reply #34March 29, 2009, 09:41:37 pm
jettabrendan
  • 198
timing
« Reply #34 on: March 29, 2009, 09:41:37 pm »
ohh okay, so im still very stumped as to what the no start problem is. Say the pump was moved when i had the head off, i did remove the bolts that hold on the pump for some reason... I could have moved it and not even realized, then bolted her back together with the pump way off?
Reply #35March 29, 2009, 09:54:47 pm
jettabrendan
  • 198
timing
« Reply #35 on: March 29, 2009, 09:54:47 pm »
i had to make my own with a 303 british casing wrapped in elec tape. it worked but prob not good enough. i seen pics of the tool and they look different as to what fits in my engine. i had to squish the end of the casing for it to fit in, its a flat slot. the tools i see were just pins.
Reply #36March 30, 2009, 07:51:22 pm
jettabrendan
  • 198
timing
« Reply #36 on: March 30, 2009, 07:51:22 pm »
what size socket do i need to take out the injectors?
Reply #37March 30, 2009, 08:04:49 pm
subsonic
  • 1836
timing
« Reply #37 on: March 30, 2009, 08:04:49 pm »
Quote from: "libbybapa"
Did you use the iming pin in the pump sprocket when installing the timing belt?
Quote from: "jettabrendan"
Have you ever lived in North or NW Maine Brendan?  The .303 case wrapped in electric tape is just beautiful man.  Classic. :lol:  :lol:  :lol:
Reply #38March 30, 2009, 08:22:50 pm
jettabrendan
  • 198
timing
« Reply #38 on: March 30, 2009, 08:22:50 pm »
no but i am from Cape Breton, close enough :) i figured it would be easy to fashion up a tool and it was the first thing i loked at haha
Reply #39March 31, 2009, 08:53:16 am
jettabrendan
  • 198
timing
« Reply #39 on: March 31, 2009, 08:53:16 am »
Anyone know the size of the socket to take out the injectors? I'm in the store right now.
Reply #40April 01, 2009, 08:40:09 am
jettabrendan
  • 198
timing
« Reply #40 on: April 01, 2009, 08:40:09 am »
okay i got the injectors out, 2 of them had DRY pre chambers.. the nozzles were dirty, i took them apart cleaned the hell outta them. While i had them out i also checked to see if the glow plugs were working and they werent.  This would probbly slve my no start problem.. BUT my other jetta starts without glow plugs, just real rough. So its probably also my timing thats out to lunch.
