Author Topic: This is just a TEST, Do not be ALARMED.  (Read 4052 times)
February 11, 2009, 04:30:26 pm
« on: February 11, 2009, 04:30:26 pm »
ha ha, I've noticed in the past that in order to get people to look at your *** you've gotta have good advertisement. like seriously right? look at all the posts that have like 5034 views! all have really attractive names..
So i did try to search this, but what i am looking for was hard to type in to the search.
I want to know if it is possible to do the whole 1.9 head on a 1.6 N/a.. would this be a good upgrade for it? if i were to do that, is there an oil passage that needs to be blocked in the head? Right now this is way out of my price range.. and piossibly skill range as well.. lol :P
just looking mainly for ideas and possibilities. lol
so waht do you guys got?
Reply #1February 11, 2009, 04:45:31 pm
truckinwagen
  • 1895
« Reply #1 on: February 11, 2009, 04:45:31 pm »
the 1.9 head should bolt up to the 1.6 block just fine, there is only need to block the oil return if you have a mechanical lifter block.
it would be an upgrade because the 1.9 head flows much better than the 1.6, but it will also lower compression a bit due to the larger prechambers making cold starts a little harder
83 Opel Kadett Diesel
Reply #2February 11, 2009, 04:46:07 pm
Dirtrag2
  • 298
« Reply #2 on: February 11, 2009, 04:46:07 pm »
try to search out "frankenmotor" you'll get all the answers you desire.
...Darcy
'97 Jetta 1.9TD ( dirtrag2 )
'88 Fox Wagon ( projekt Dirtrag 3 )
Reply #3February 11, 2009, 05:50:35 pm
« Reply #3 on: February 11, 2009, 05:50:35 pm »
oh i guess i forgot to add that IF i were to do this, i would also invest in a VNT. lol
Reply #4February 11, 2009, 06:16:13 pm
« Reply #4 on: February 11, 2009, 06:16:13 pm »
Quote from: "libbybapa"
I wouldn't do it on a non-turbo motor.  I doubt you'd find it flowed enough better with zero boost to make any positive difference.
Andrew
i remember looking at a cutaway of both the 1.6 & 1.9 cylinder heads, and the 1.9 is a huge improvement.  the 1.6 could be ported to produce 'similar' results, but definitely not as good as the 1.9.
my personal belief is that for mild engine performance, it should work ok.  it might even shock everyone and perform quite well if ported & polish in conjunction with the long runner intake system, and using a large free flowing exhaust system. the piston tops could be coated with a heat reflecting material as well, which would really help.  all of the extra airflow should really wake the motor up!!!
and as always, a VNT turbo would really whip the car in the ass in terms of driveability...  the only economical way of building such a motor, IMO, would be to use a complete 1.9 prothe head.  i wonder when he will start selling the valve cover with his head?  Smokey Eddy's build really turned out quite well... i think he has set a precedent here  :lol:
Reply #5February 11, 2009, 06:39:59 pm
« Reply #5 on: February 11, 2009, 06:39:59 pm »
Quote from: "jtanguay"
Yeah i read his entire post and shot him some pm's. he has definetly set something.. Says the thing runs like TITS lol
I dunno if it would even be in the late future.. but it definetly sounds COOL
a ported 1.9 head, long runner gasser intake, free flowing dual outlet exhaust, and a Vnt.. that thing would be a rockin n/a! :P
Reply #6February 11, 2009, 07:12:16 pm
« Reply #6 on: February 11, 2009, 07:12:16 pm »
Quote from: "truckinwagen"
So if it were a 91 n/a in question with Hydro head.. id be good, direct swap. niice
Reply #7February 11, 2009, 07:30:55 pm
« Reply #7 on: February 11, 2009, 07:30:55 pm »
Quote from: "8v-of-fury"
yea.. there really isn't much holding you back now, man.  nudge nudge!!!   :lol:
Reply #8February 11, 2009, 07:33:27 pm
« Reply #8 on: February 11, 2009, 07:33:27 pm »
SADLY there is alot.. you know what is ***ty to happen to you in life? and is even more ***ty to experience at 18?
Being laid-off. ***e it sucks.. and right in the middle of an engine swap project.. thats gonna back burner for a while sadly..  but yeah! Sounds like a good route to go for sure!
Reply #9February 11, 2009, 07:58:55 pm
truckinwagen
  • 1895
« Reply #9 on: February 11, 2009, 07:58:55 pm »
I hear you there man, I work seasonally(summertime for 3 months) and I am starting to run out of money for my projects, so they will be put on the back burner until april when I get my tax return :D
Reply #10February 11, 2009, 08:00:00 pm
  • 3468
    • McScrubbins Body Wash
« Reply #10 on: February 11, 2009, 08:00:00 pm »
Me too budd.
I don't know why i can't get a job either. Its no where near as bad in canada as it is in the states... holy!
Reply #11February 11, 2009, 08:34:02 pm
« Reply #11 on: February 11, 2009, 08:34:02 pm »
all too true unfortunately...  i'm currently jobless as well, but i have a few aces up my sleeve in terms of financing my future projects  8)
if it turns out well enough, i may be able to assist my fellow dubbers  :wink:
Reply #12February 12, 2009, 04:48:16 am
« Reply #12 on: February 12, 2009, 04:48:16 am »
I have an AAZ head you can have for free. It's complete. May or may not have a valve cover, I forget.
It's not in the best of shape, but I think it is still usable.
Come get it when you get those glowplugs.
Reply #13February 12, 2009, 08:50:42 am
« Reply #13 on: February 12, 2009, 08:50:42 am »
duuuude, your the best! :P
sadly, i haven't a clue when that will be. hopefully i can find another at least ***ty paying job soon so i can keep driving my car and buying some ***...
I HaTe ReCesSionS~!
Reply #14February 12, 2009, 11:59:28 am
addautomotive
« Reply #14 on: February 12, 2009, 11:59:28 am »
... you know what is ***ty to happen to you in life? and is even more ***ty to experience at 18?
Being laid-off...
Ha, try 33 with your first-born on the way in 8 weeks.
