Author Topic: EGT Guage  (Read 8129 times)
Reply #30February 16, 2009, 07:54:26 am
53 willys
EGT Guage
« Reply #30 on: February 16, 2009, 07:54:26 am »
diesel are known to have a long long life...if your turning up the power you really need a good gauge...$100 gauge can save your $500 turbo or add lots of extra life to the turbo....I'm all for saving cash and doing a budget build..but sometimes you need to spend the money!! :wink:
Reply #31February 16, 2009, 08:12:03 am
EGT Guage
« Reply #31 on: February 16, 2009, 08:12:03 am »
I agree, there are somethings you can do economically but I do not belive gauges are one.
Reply #32February 16, 2009, 11:00:20 am
  • 3468
    • McScrubbins Body Wash
EGT Guage
« Reply #32 on: February 16, 2009, 11:00:20 am »
I had no idea that Aircraft Spruce's set up was $80?!?! I thought they were all hundreds.
Reply #33February 16, 2009, 11:22:37 am
arb
EGT Guage
« Reply #33 on: February 16, 2009, 11:22:37 am »
Quote from: "Smokey Eddy"
Many of us building aircraft from plans are real cheapskates !!! Here's the plane I was building, but my wife wants me to start over with one that lands on water since we moved to a lake...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=300292722571&sspagename=STRK%3AMESELX%3AIT&viewitem=
Reply #34February 16, 2009, 11:50:13 am
53 willys
EGT Guage
« Reply #34 on: February 16, 2009, 11:50:13 am »
for some reason airplane building is not something I would go "cheap" on either!!  :shock:  :shock:
Reply #35February 16, 2009, 12:57:10 pm
Heavy D
  • 10
EGT Guage
« Reply #35 on: February 16, 2009, 12:57:10 pm »
post the link of the gauge! can't find the right one i must be blind
1.6turbo
Reply #36February 16, 2009, 02:46:47 pm
Heavy D
  • 10
EGT Guage
« Reply #36 on: February 16, 2009, 02:46:47 pm »
Does it come with the complete kit? everything i did to makt it work
thxs for the link
1.6turbo
Reply #37February 16, 2009, 11:59:57 pm
Heavy D
  • 10
EGT Guage
« Reply #37 on: February 16, 2009, 11:59:57 pm »
(mk2) im putting the gauge just above the heat control
1.6turbo
Reply #38February 17, 2009, 04:54:50 am
hamradio
  • 282
EGT Guage
« Reply #38 on: February 17, 2009, 04:54:50 am »
Right now, for my egt gauge, I'm using a $45 ebay 12v digital temp controller, with aircraft spruce thermocouple.  Works great.
Reply #39February 17, 2009, 10:27:08 am
arb
EGT Guage
« Reply #39 on: February 17, 2009, 10:27:08 am »
Quote from: "53 willys"
Cheap is a relative term in aircraft... if you build from plans, you can make each part one by one. You should still use aircraft quality materials if the part is structural, but for non-structural why use a $63.60 2"x4" spruce when a $1.77 stud from Home Depot will work just as good?
The gauges are the same thing.. an $80 EGT setup is cheaper than the $66,745.00 Garmin G900X system we would love to display our EGT next to the Highway in the Sky GPS :-D
https://buy.garmin.com/shop/shop.do?pID=419#g900x
Reply #40February 17, 2009, 11:53:26 am
  • 3468
EGT Guage
« Reply #40 on: February 17, 2009, 11:53:26 am »
yeah prothe's gauge starting at 600 and going to 24,000 is pretty stupid now that i've driven a bit. but it does what i want it to do. so im happy. That's a neat idea with mixing and matching the sender with other types of displays. I like that.
Reply #41February 17, 2009, 01:33:49 pm
GEE-BEE
  • 1604
EGT / TIT GAUGE
« Reply #41 on: February 17, 2009, 01:33:49 pm »
I PERFER THE ONE AT KERMITDI.COM
Iam doing in my center console : ( GTI Mk1 Type )
TIT / EGT
WATER/VOLT
OIL PSI / OIL TEMP
There back lit for night use
You get what you pay for...
Gee-Bee
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
