Author Topic: Turbo on my 1.6 NA for now, a few questions.  (Read 4839 times)
February 01, 2009, 07:20:42 am
kaneb
  • 164
    • www.dasdubbers.org
« on: February 01, 2009, 07:20:42 am »
Hi-
I have a few questions.  I have a TD in the works for a build but probably wont get to it it till next fall.  Im going to put my turbo set-up on my NA running low boost for a little more power and MPG.  I have a couple questions since when my TD came it wasn't completley assembled and can't seem to find the info in my vw bible..i mean bentley.
Ok so i have a picture i stole from the site and marked what i have questions about so i dont have to explain as much.
Where the red marks are.  The crank case ventilation goes to the air intake.  And also on my intake manifold on right (pass.) side there is that black chumy what exactly is it and do and does it also go to the intake piping?
I want to put the TD stock oil cooler from under the oil filter flange on as well,  Can i just tap into the coolant lines?  or do i need to use the the TD water pump.  i think i can just plum it in can i not?
Usually your boost tubing runs from the boost enrichment on a td?  can i plum mine in still with just the na pump so i can run my boost gauge?
Last one for now, My Na pump is like new runs like a top, is it that much different from the td pump?  Possible to take off the top of it and install the boost enrichment onto my NA pump?
These are my questions, I have a few i know, Thanks in advance for any help as im setting into this today.
I have my egt tapped in the exhaust manifold ready to go and a boost. Now to hunt a tach down :roll:
Kane
2004 Tdi sport-daily
1983 Rabbit TD-go kart
www.dasdubbers.org
Reply #1February 01, 2009, 10:47:54 am
« Reply #1 on: February 01, 2009, 10:47:54 am »
The "black chummy" is the factory blow off valve.  It's purpose was to open and release "excess" pressure from the intake in the event that the wastegate failed on the turbo.  Factory boost was set to about 9 PSI, the blow off valve is supposed to open at 12 PSI.
If you're planning on keeping the boost at or below stock levels then yep, just connect it to the intake like in the photo above. It will be closed all the time and won't ever actually do anything.  Basically the only time you need to mess with it is if you're planning on turning your boost up over stock, then it needs to be eliminated/disabled.
Reply #2February 01, 2009, 12:33:02 pm
kaneb
  • 164
« Reply #2 on: February 01, 2009, 12:33:02 pm »
ok thanks, i new it had something to do with boost and heard about plugging it when going up in boost but never actually new what it specifically did.
Kane
www.dasdubbers.org
Reply #3February 01, 2009, 01:21:58 pm
  • 3468
    • McScrubbins Body Wash
« Reply #3 on: February 01, 2009, 01:21:58 pm »
hey that's my old 1.6td head :D !
You want this one now ;) updated version
just uhhh never mind the wine cork and masking tape. It's temporary ok!
Reply #4February 01, 2009, 01:38:00 pm
« Reply #4 on: February 01, 2009, 01:38:00 pm »
:D
Reply #5February 03, 2009, 04:11:19 pm
kaneb
  • 164
« Reply #5 on: February 03, 2009, 04:11:19 pm »
Thanks guys,
Alright so anyon know about how i should go about with my boost tubing since i dont have the boost enrichment on my pump?  Also is it possible to swap the boost enrichment onto my na pump as it is in good condition?
Thanks,
Kane
www.dasdubbers.org
Reply #6February 03, 2009, 07:08:22 pm
« Reply #6 on: February 03, 2009, 07:08:22 pm »
where could one get the oil separator? I still need one for my build. Can you substitute anything else? What are the internals like on the inside of this hockey puck?
Reply #7February 03, 2009, 07:21:00 pm
Rabbit TD
  • 840
« Reply #7 on: February 03, 2009, 07:21:00 pm »
Quote from: "theman53"
When I was cleaning all my parts for my T/D rebuild I wondered how that thing worked too.  Looking into the hole at the bottom of it where it goes into the valve cover it looks to be nothing more than a baffle type thing to me to not let as much oil pass through it and doesn't look like there is anything to wear out on it other than that damn little grommet in the valve cover that costs $7 if you need one and I did :lol:
Reply #8February 05, 2009, 05:07:29 am
kaneb
  • 164
« Reply #8 on: February 05, 2009, 05:07:29 am »
So im getting closer ot the end of getting my turbo set-up.  I am just curious do people find the stock oil cooler to help alot?  I have to kind plum my lines in a bit differently.  It will still be going with the flow.  Just curious how much does it lower oil temps?  Anyone know?
Thanks--Kane
www.dasdubbers.org
Reply #9February 05, 2009, 12:57:10 pm
truckinwagen
  • 1895
« Reply #9 on: February 05, 2009, 12:57:10 pm »
from what I hear what it does best is help the oil get up to operating temp faster, which is good for all your engine bits.
83 Opel Kadett Diesel
Reply #10February 06, 2009, 03:48:09 pm
kaneb
  • 164
« Reply #10 on: February 06, 2009, 03:48:09 pm »
thanks.  got the lines have to hook them up still.  Anyone know about my pump question regarding the boost enrichment going on a NA pump?
Kane
www.dasdubbers.org
Reply #11February 06, 2009, 03:58:25 pm
  • 3468
« Reply #11 on: February 06, 2009, 03:58:25 pm »
I'm not entirely sure about the pump thing. You may be able to contact Giles about a trade; your NA pump for a turbo pump?
ps. I hate this thread so much because it reminds me of my piece of ass head that caused me SO much grief. :P  but then the second pictures comes with a *ssssssiiiiiiigggggghhhhhh* of relief!
Reply #12February 07, 2009, 06:11:04 am
kaneb
  • 164
« Reply #12 on: February 07, 2009, 06:11:04 am »
gotcha, Well The picture has helped out alot so thank you.  Your build was nice mine.  Got some pointers off of it.  I have the turbo set-up on my car.  Runs good have to get my boost and egt gauge set-up then i will start adjusting if the fuel needs to go up or boost down vice versa.  I still have to pick up a VDO tach for the car too.  I am wondering should i get the 6000 rpm or the 4000 im guessing 6 since these redline at like 5 right?
It's runing awesome, sounds alot better too.  I just have the stock down pipe no exhaust until i get my 3" turbo back made up.  But it sounds quiter then the stock NA exhaust.  You can really hear the turbo whistle.
You guys have all been a huge help thank you. Ill have pics and video later.
Kane
www.dasdubbers.org
