Author Topic: 1.9 aaz passat transmission question  (Read 2270 times)
January 28, 2009, 09:57:50 pm
vixentd
  • 88
« on: January 28, 2009, 09:57:50 pm »
Will a tdi transmission bolt up to this motor and lower my rpm range?  Stock axles bolt up and linkage?
Will a golf or jetta transmission work?
Thanks
Reply #1January 28, 2009, 11:08:44 pm
MJF
  • 581
Re: 1.9 aaz passat transmission question
« Reply #1 on: January 28, 2009, 11:08:44 pm »
Quote from: "vixentd"
Yes
If it is TDI.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #2January 29, 2009, 04:58:03 am
« Reply #2 on: January 29, 2009, 04:58:03 am »
Pretty much exactly what MJF said. You'll want to get a 02A transmission
Reply #3January 29, 2009, 06:24:46 am
MJF
  • 581
« Reply #3 on: January 29, 2009, 06:24:46 am »
All Passats have 02A from factory.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #4January 29, 2009, 06:27:25 am
stewardc
« Reply #4 on: January 29, 2009, 06:27:25 am »
I think the AAZ uses a rod shifted 020, guys. At least my Passat doner did. The TDI tranny was a cable-shift 02A. VERY different.
Reply #5January 29, 2009, 07:30:22 am
MJF
  • 581
« Reply #5 on: January 29, 2009, 07:30:22 am »
Quote from: "stewardc"
It´s not from factory.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #6January 29, 2009, 09:54:50 am
« Reply #6 on: January 29, 2009, 09:54:50 am »
i know someone with a cable shift '93 passat with a 1.9 AAZ.  he sold it to Giles.  He then installed the TDI box.  maybe some came with it and some didn't?  regardless, the whole shifter assembly can be taken out and swapped either way (to cable or to rod, or you can pony up and install a cable shift if not)
Reply #7January 29, 2009, 10:32:26 am
« Reply #7 on: January 29, 2009, 10:32:26 am »
Cable shift is highly superior.
The transmissions are tougher as well.
Reply #8January 29, 2009, 11:15:45 am
MJF
  • 581
« Reply #8 on: January 29, 2009, 11:15:45 am »
You can check from etka, Passat never had 020. Even 1,6 carb had 02A :)  Everything can be installed afterwards, that can explain stewardc´s doner Passat
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
