Author Topic: Who Can rebuild my T3 Turbo?  (Read 5324 times)
January 18, 2009, 01:07:00 pm
zagarus
  • 619
« on: January 18, 2009, 01:07:00 pm »
Who here can rebuild turbos or recommend someone in the PNW?  I would like to get my Garrett T3 rebuilt as it has a good amount of shaft play.
Thanks
Thomas
Reply #1January 18, 2009, 01:08:10 pm
53 willys
« Reply #1 on: January 18, 2009, 01:08:10 pm »
you could do it yourself???
I did and it's pretty darn easy....
Reply #2January 18, 2009, 02:14:56 pm
boosted_diesel_84
  • 216
« Reply #2 on: January 18, 2009, 02:14:56 pm »
just make sure u send it out to a turbo shop to have it balanced after u rebuild it. i just sent mine to G- Pop shop in arizona and it was about $325 which i dont think is bad
.0020 over block,balanced,blueprinted,8lb flywheel,Stage 2 clutch,ported and ceramic coated head manifolds,turbo,pistons, SS valves, PP 2.5in DP,Intake, 3" ex.GTD nozzles, Built pump, windage tray,36mm pump,ARP Studs.etc.My build thread http://www.vwdiesel.net/forum/index.php?topic=15461.0
Reply #3January 18, 2009, 03:04:41 pm
dillenger1
  • 777
« Reply #3 on: January 18, 2009, 03:04:41 pm »
325 for balancing?theres a guy on ebay that does them for cost of the kit.he owns a turbo shop.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #4January 18, 2009, 05:14:42 pm
Rabbit TD
  • 840
« Reply #4 on: January 18, 2009, 05:14:42 pm »
Quote from: "dillenger1"
I've always wondered, how do they actually balance a turbo?  Do they take the assembled shaft and set it in some kind of device like a v block and see where it stops when it is rotated and cut material so it stops at random positions or something like that, something similar to a R/C airplane propeller balancer ? :?:
Reply #5January 18, 2009, 05:43:46 pm
dillenger1
  • 777
« Reply #5 on: January 18, 2009, 05:43:46 pm »
they balance the shaft with an electronic machine that spins it and shows where material needs to be removed to balance.
Reply #6January 19, 2009, 06:59:12 pm
boosted_diesel_84
  • 216
« Reply #6 on: January 19, 2009, 06:59:12 pm »
No, that was for a complete rebuild. i was just stating that a balance should be performed after a rebuild.
Reply #7January 19, 2009, 07:08:24 pm
Rabbit TD
  • 840
« Reply #7 on: January 19, 2009, 07:08:24 pm »
Something similar to a mini wheel balancer type thing then, I know for a fact they are accurate if they're calibrated.
Reply #8January 19, 2009, 07:16:45 pm
Luckypabst
  • 502
« Reply #8 on: January 19, 2009, 07:16:45 pm »
Alamo Turbocharger went far out of their way to find me the correct KKK parts for my K14. They're in the PNW (Kent, WA) and Canada.
http://www.alamoturbochargers.com/contact.html
Chris
'82 TD Westy
'81 NA Caddy
Reply #9January 20, 2009, 06:56:24 am
foxracer1
  • 991
« Reply #9 on: January 20, 2009, 06:56:24 am »
I did my own with a kit from Gpopshop.com and had the wheels balanced for $65 at the local diesel injection/turbo shop. Works great been boosting 20+ since. I'd recomend getting the 360 degree thrust plate.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #10January 20, 2009, 08:36:04 am
« Reply #10 on: January 20, 2009, 08:36:04 am »
Quote from: "foxracer1"
I've not asked why but for some reason Giles doesnt recomend the 360 I'm told..?
Tyler??
Reply #11January 20, 2009, 10:36:17 am
« Reply #11 on: January 20, 2009, 10:36:17 am »
Better ask Giles, I'm not sure
Reply #12January 20, 2009, 02:32:12 pm
« Reply #12 on: January 20, 2009, 02:32:12 pm »
Oh man!! What help are you???
Reply #13January 20, 2009, 02:52:00 pm
  • 3468
    • McScrubbins Body Wash
« Reply #13 on: January 20, 2009, 02:52:00 pm »
If you change the oil seals do you have to get it balanced afterwards?
Reply #14January 20, 2009, 03:11:04 pm
« Reply #14 on: January 20, 2009, 03:11:04 pm »
Its always recommended but it also (as far as I'm concerned) depends on the turbo.
KKK balances the shaft and turbine separately from the compressor wheel so I don't worry about those. On a T3 I'm ULTRA careful to make sure it goes back together the sane way it came apart.
