Author Topic: Oil Pressure Specification for 1.6 and search help  (Read 2419 times)
January 05, 2009, 06:48:27 pm
Tony2ltr
  • 53
« on: January 05, 2009, 06:48:27 pm »
Ok I give up, I have been looking for an hour for someone that may have posted an lube oil pressure spec for the 1.6 turbo engine. if you have it, great!
if there is a post I should have been able to find after an hour of searching, please show me the error of my ways.
I searched for "oil pressure specification", "Oil and pressure and specification and 1.6" and multitudes of variations.
I am about to install my overhauled 1.6 and would like to know what to look for when it fires!
THANKS!
-Tony
92 Jetta Ecodzl/biodzl/WVO/meth-H2O turbspray
1969 Subaru 360 Sambar (converted to Electric)
1975 Chevy Cosworth Vega Turboed
1991 Toyota Pickup (megasquirted)
2004 POS Honda Civic (I'll never buy another)
2 cylinder Lister Petter diesel CO-Gen unit
Reply #1January 05, 2009, 09:41:23 pm
VW_Commuter
  • 355
« Reply #1 on: January 05, 2009, 09:41:23 pm »
The Bentley manual states:
Oil pressure, minimum at 2000 rpm with SAE 10W oil at 140F (68C)....2.0bar (28psi)
Greg
'06 Golf TDI traded in for a '12 Jeep Rubicon (the Phatbox is available)
'91 Jetta TD, a work in progress (I'll do a build thread when I start in earnest)
'65 Notchback, a project not yet started
Reply #2January 06, 2009, 07:01:41 pm
Tony2ltr
  • 53
« Reply #2 on: January 06, 2009, 07:01:41 pm »
Thank you very much. It is almost ready to fire up. For right now, how about 75 psi during cranking with 15W40 Rotella at 20 degrees F?.  This is what I got on the floor of the garage!
-Tony
Reply #3January 07, 2009, 03:15:56 am
gsodonis
  • 14
My 1.6TD pressure
« Reply #3 on: January 07, 2009, 03:15:56 am »
If it's any help at all, my newly rebuilt 1981 Rabbit 1.6D to TD conversion with 36mm oil pump idles at 120PSI cold at 20 degrees F. Once warm, it will run at 60 - 80 PSI on the HWY and idle at around 30 PSI.
Reply #4January 07, 2009, 05:07:00 am
Tony2ltr
  • 53
« Reply #4 on: January 07, 2009, 05:07:00 am »
That does help. every little bit of information helps to build a picture.
-Tony
