Author Topic: VNT15 vs t3?  (Read 3599 times)
December 30, 2008, 05:02:21 pm
hamradio
  • 282
VNT15 vs t3?
« on: December 30, 2008, 05:02:21 pm »
Hi,
Right now I'm running a vnt15 at about 15 psi on 1.6na rabbit.  Lots of fun.
I have 3 or 4 t3's laying around, too.  I'm kinda tempted to make a log manifold and put a t3 on.
Any opinions on this?  Advantages/disadvantages of each?
Thanks.
Reply #1December 30, 2008, 05:52:38 pm
TurboJ
  • 661
VNT15 vs t3?
« Reply #1 on: December 30, 2008, 05:52:38 pm »
Why would you like to take a 30-year step back?
If you want more power just move onto a bigger VNT - you have already gone through the trouble of adapting a modern turbo on your VW so why not stick with VNTs?
Jetta II 1.6 TD 'Project 200'
Reply #2December 31, 2008, 07:12:48 pm
andy2
VNT15 vs t3?
« Reply #2 on: December 31, 2008, 07:12:48 pm »
The t3 will give more air at the top end but there is an enormous amount of lag when compared to the vnt15.The t3 will need more fueling all around to make it work well.You could try the t3 if you havn't seen them in action before but I think that you would end up enjoying the 15 psi form the vnt over 22 psi from the t3.The T3 would basically only start to make 1 psi after the vnt maxed out at 15psi for example.A bigger vnt would be Ideal as TurboJ suggests however they can be hard to come by depending on where you live.
Reply #3December 31, 2008, 08:32:44 pm
  • 3468
    • McScrubbins Body Wash
VNT15 vs t3?
« Reply #3 on: December 31, 2008, 08:32:44 pm »
or.... If you're making your own manifodls why not have both?
Just putting it out there  :twisted:  :twisted:  :twisted:
T3's can make some wicked boost. I read a claim the other day of 40 psi on long pulls.
Reply #4January 01, 2009, 05:27:05 am
dillenger1
  • 777
VNT15 vs t3?
« Reply #4 on: January 01, 2009, 05:27:05 am »
Quote from: "Smokey Eddy"
that power is really not useable though because its so far down the line,I myself am looking for a k14 or a vnt.What makes these motors shine is the pull off the line.I know i have to be way out in third on my truck before im making that boost.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #5January 01, 2009, 06:05:42 am
VNT15 vs t3?
« Reply #5 on: January 01, 2009, 06:05:42 am »
Heres what you do. You give me the 15 and your set up for it and I will give you my kkk24.
Seriously, I haven't even owned a TD yet, just building one, but from what I have heard and experienced in the GMC diesel with the variable vane turbo I would love to have one. I have seen some VNT17 on fleabay before, but looks like more coin than I care to shell out.
Reply #6January 01, 2009, 03:26:42 pm
  • 3468
VNT15 vs t3?
« Reply #6 on: January 01, 2009, 03:26:42 pm »
Quote from: "dillenger1"
Hence the compound set up!!! :D
