Author Topic: fuel mileage  (Read 7140 times)
December 22, 2008, 12:01:39 pm
1life2live
fuel mileage
« on: December 22, 2008, 12:01:39 pm »
Just curious what everyone is getting for fuel mileage with or without mods. All i have done is turned the fuel screw in 1/2 turn and spun the pin in the lda and set the boost to 18psi and on this last tank i only got 37mpg. :( Just wondering if thats close to everyone else or if maybe i have something off like the pump timing and im wasting to much fuel. Lets see what everyones getting and what kind of mods you have.
Reply #1December 22, 2008, 12:08:51 pm
fuel mileage
« Reply #1 on: December 22, 2008, 12:08:51 pm »
Winter's very hard on a diesel's fuel economy... winterized fuel has fewer BTUs, tires are stiff, oil is thick, snow is hard to push thru, and engine takes much longer to get to efficient operating temperatures.
The literature reports declines between 10-25% for diesel-powered cars during the winter.
Other factors:  engine size ?  chassis ?  ratio of highway/city ?  Driving style ?  Hills ?
BTW, there's people on this forum from all over the globe so we'll need to know your location.  I'm betting my gallons are not the same as your gallons ??!! :wink:
To (finally) answer your question:  my 1.9l AAZ, with about 10K miles since rebuild, using dino 10W30 breakin oil, a hot pump, 20+ psi of boost, Goodyear Blizzaks,  is getting about 35 miles to the US gallon.... all of it in the city, at temperatures around -15F.
Reply #2December 22, 2008, 12:31:19 pm
TurboJ
  • 661
fuel mileage
« Reply #2 on: December 22, 2008, 12:31:19 pm »
When my Jetta was still stock, it did 46.76 MPG for the last tankful.
That was including some quick back-road driving and performance measurements as well.
All stock, except boost turned to 1.2 bar (about 17 psi) and fuelling turned a bit up. That MPG was measured over a drive of  ~1000 km.
Jetta II 1.6 TD 'Project 200'
Reply #3December 22, 2008, 01:14:56 pm
zozep
  • 176
fuel mileage
« Reply #3 on: December 22, 2008, 01:14:56 pm »
1.6 stock aside from a bad ass pump from Giles, K&N panel filter, WG blocked off boosted up to about 23 lbs, 2.5 straight pipe.
I can't say I've noticed a 25% economy drop maybe.....8% :)
I always fill up at Shell using their Ultra Diesel and I use 100ml of Crappy Tire's Diesel Additive on every fill up. I use Shell Rotella 10W40.
I would say 30-40% of my driving is on snow covered roads, and I'll rarely take it up to redline, most of my driving is highway driving keeping it between 85 and 110 kmph. When I fill up, I always fill the tank right up to the top pushing the air vent button inside, which usually adds a good 2-3 minutes to my fill up and a few bucks more on the bill.... I plug my cars block heater into a timer at night, it will heat the car about 4 hours before I wake up to go to work.
All this being said, I always see 800 a tank I'm sure I could get up to 900 - 950, but I don't know how far into the red I can take the fuel gauge before I have to get out and push.
Cheers from Ontario.
SOLD: 92 Jetta TD, Giles Pump set to 30 psi, MLS Head Gasket, ARP head studs, Huge eBay intercooler, blocked WG, FK suspension, 1.9L AAZ downpipe to 2.5 inch straight back.
Current: 2000 TDi, 01M :(  DG Full skid plate, Cat 2 micron Fuel Filter, Scanguage II, 4700kHIDs, DG RacePipe
Reply #4December 22, 2008, 01:25:37 pm
1life2live
fuel mileage
« Reply #4 on: December 22, 2008, 01:25:37 pm »
great answers and thanks for the quick replies. i forgot to mention that i live in md and it is bitter cold right now but the last tank of fuel the temps were between 30-45 degrees. I also have a 2.5 inch turbo back straight exhaust and k and n drop in filter along with the increased boost and turned up fuel. I also plug the car in at night and let it warm up for about 10 minutes before i go to work. I know the idle time hurts mpg average so i am considering that.
Kepp the info coming
Reply #5December 22, 2008, 01:34:37 pm
MJF
  • 581
fuel mileage
« Reply #5 on: December 22, 2008, 01:34:37 pm »
Audi 80 1,6 TD 170hp. Usually 5,7-6,2 litres/100km @ full tank(~38-41MPG) Used all the hp:s :lol: Best one tank was 5,1 litres/100km, ~46MPG
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #6December 22, 2008, 02:15:46 pm
catlin_cava
  • 1954
fuel mileage
« Reply #6 on: December 22, 2008, 02:15:46 pm »
1.9AAZ, No mods, On my last full tank...around 500km on 50Liters...Not to fuel efficient
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #7December 22, 2008, 02:44:49 pm
fuel mileage
« Reply #7 on: December 22, 2008, 02:44:49 pm »
I live in AK so temps nowdays are -15F, 10F, sometimes it stays -40F for a few days straight dropping to -55F once in a while.
MPG got down to 33 'till I retarded the timing a bit now it's 38-41mpg.
Also a couple weeks ago I started running delo 400 10w-30 onstead of 15w-40.
Reply #8December 22, 2008, 03:33:19 pm
Jettagli16v
  • 344
fuel mileage
« Reply #8 on: December 22, 2008, 03:33:19 pm »
Florida weather:
(A bitter cold 55 right now!!)
Stock motor, Large K&N intake, and 19 PSI (MBC) otherwise stock. 1985 Jetta T3 TD.
as high as 41.6 (Trying to use the upshift indicator... some of the time!)
and as low as 34-35 MPG (Trying to bury every honda product in diesel smoke)
I also cannot cruise the highway (most of my driving) at any less than 70mph. Its florida, and you will get run over in the slow lane doing 60 in a 50 zone....
But I bet if I could drive one whole tankful like my dad drives, I could easily (?) see the 45-49 MPG many report (Many over 50 years old, that is!)
nothing personal, but I gotta GO!!
-Brad
Reply #9December 22, 2008, 06:13:03 pm
1life2live
fuel mileage
« Reply #9 on: December 22, 2008, 06:13:03 pm »
Quote from: "NoSurrenderAG"
Quote from: "1life2live"
I'm in Maryland too where might you be? We are so so rare around here..
Im in Carroll County with all the hillbillies in diesel pickups who think stacks give you 500hp.
Looks like ,y mileage may not be to far off then i was thinking of letting a shop double check my pump timing but with the answers im getting it looks like im close.
Reply #10December 22, 2008, 07:31:09 pm
fdnyguy
  • 499
fuel mileage
« Reply #10 on: December 22, 2008, 07:31:09 pm »
And the news here in NY reports on a cold freeze at 13 degrees F.... :)
Never forget what a "Religion of Peace" did on 9/11/01.
2015 Passat TDi. 27k
1998 Jetta 1.9TTDi 228k .
2002 F250 7.3 TD   63,000 miles. Sold.
1980 Mack CF Fire Engine. Working on it.
2007 Dodge MegaCab 5.9 Cummins. Nice, but plagued with issues
Reply #11December 22, 2008, 10:19:46 pm
fuel mileage
« Reply #11 on: December 22, 2008, 10:19:46 pm »
Quote from: "fdnyguy"
Well, we don't call it the Great White North for nothing !! :wink:
Tonight's low will dip below -35C... that's -31F.  Good battery, good oil, good compression, good glowplugs... no worries !
Reply #12December 22, 2008, 10:31:34 pm
cyrus #1
  • 360
fuel mileage
« Reply #12 on: December 22, 2008, 10:31:34 pm »
Quote from: "Vincent Waldon"
You forgot the heated garage to park the car in.  :lol:
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #13December 23, 2008, 06:55:28 am
arb
fuel mileage
« Reply #13 on: December 23, 2008, 06:55:28 am »
My 1.6L NA Rabbit MK1 consistently got 49  - 51 mpg. Most of my driving was highway at 65 mph with a 5 speed. No a/c, no power anything. I'll let you know when I'm driving the Dodge caravan with the 1.6T what kind of numbers I see. Should be in the next couple of weeks. In SE Michigan they tend to keep the roads free of snow most of the time. I did not notice an increase in the winter. Remember, at least for an NA, the cold winter air packs more O2 in the cylinders for better efficiency after warm-up. Maybe my long highway drives with more O2 made up for the extra burn to get to temp. I never let mine idle to warm the engine as I had a block heater.
Reply #14December 24, 2008, 10:35:02 am
fdnyguy
  • 499
fuel mileage
« Reply #14 on: December 24, 2008, 10:35:02 am »
Great White North is an understatement with some of the blizzard photos I've seen over the years.
31 below? No doubt 31 above is bikini weather.. :)
Merry Christmas. Stay safe, stay well, stay warm.....
